Running interDyMFoam in parallel
Old   March 5, 2009, 13:20
Default Hello World. I tried to run
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
I tried to run an interDyMFoam case in parallel.
I first run the decomposePar and split the domain into two.
After running mpirun -np 2 interDyMFoam -parallel >log there is this entry in the log-file:
DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
[0] #0 Foam::error::printStack(Foam:: Ostream&)
and still one processor is running interDyMFoam.
What went wrong?
BTW I'm using a 64bit machine.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 12, 2009, 06:54
Default Meanwhile I got the solver to
sega's Avatar
Sebastian Gatzka
Meanwhile I got the solver to work on two processors, but the computational time is the same as with one processor.
Although the two processors were busy the corresponding processor-directories are empty and the main directory is filled with the final solution directories.
I think there is something wrong, but I have no idea what it may be.
Maybe I made a mistake splitting the domain (which is containing a cyclic bc)?
decomposeParDict
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 19:31
Running in parallel Rasmus Gjesing (Gjesing) OpenFOAM 35 March 31, 2011 19:21
InterDyMFoam dynamic messing in parallel fails under nonquiescent conditions adona058 OpenFOAM Running, Solving & CFD 5 August 19, 2010 12:47
Problem in running Parallel mamaly60 OpenFOAM Running, Solving & CFD 1 April 19, 2010 12:11
InterDyMFoam dynamic meshing in parallel fails under nonquiescent conditions adona058 OpenFOAM Bugs 7 November 18, 2008 15:58
