Running dieselFoam error
Like Tree8Likes
Old   October 28, 2005, 07:43
Default To be honest I'm still working
  #21
Assistant Moderator
Bernhard Gschaider
To be honest I'm still working with the downloaded binary distribution (I've avoided recompiling the official distribution, because other people are using that installation too).
I'll install me a separate copy and give it a try.
(On the other hand by using the official binaries I am pretty sure that it's not my/my compilers fault. BTW: Could anyone reproduce this problem or is it something that only happens with my installation? - Can't imagine how, but ...)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 3, 2005, 12:49
Default It's happening to me too. In t
  #22
Ervin Adorean
adorean is on a distinguished road
It's happening to me too. In the /lagrangian subdirectory, the output is only "points".
I haven't got the time to take an in depth look to the problem though.
Ervin
adorean is offline   Reply With Quote
Old   November 6, 2005, 10:39
Default My mistake. The output in the
  #23
Ervin Adorean
My mistake. The output in the /lagrangian subdirectory is "positions".
Another thing. Is there a problem in restarting a dieselFoam case? It gives a message of out of range temperature, T=1e+163 or something similar.
Thanks.
Old   November 7, 2005, 07:01
Default I think I've found the mistake
  #24
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
I think I've found the mistake.
Have a look into src/lagrangian/basic/Cloud/CloudIO.C
and comment the readFields() and writeFields() routines.
N
niklas is offline   Reply With Quote
Old   November 7, 2005, 10:37
Default maybe this wasnt such a brilli
  #25
niklas's Avatar
Niklas Nordin
maybe this wasnt such a brilliant idea after all, it will break other things....
N
Old   November 7, 2005, 22:10
Default Nope, not a good idea... but I
  #26
Hrvoje Jasak
Nope, not a good idea... but I'd still like a bug fix. :-) Could you please post it when you figure it out.
Thanks,
Hrv
Hrvoje Jasak
Old   November 8, 2005, 07:04
Default ok, this works... as above
  #27
niklas's Avatar
Niklas Nordin
ok, this works...
as above remove the stuff from CloudIO.C
and add the lines below to src/lagrangian/basic/passievParticle/passiveParticleCloud.C
template<>
void Cloud<passiveparticle>::readFields()
template<>
void Cloud<passiveparticle>::writeFields() const
and the corresponding to indexedParticleCloud.C
is this acceptable?
N
Old   November 8, 2005, 10:20
Default > is this acceptable? nope...
  #28
niklas's Avatar
Niklas Nordin
> is this acceptable?
nope...
Just declare readFields() and writeFields() as virtual in Cloud.H, i.e.
//- Write the field data for the cloud of particles
virtual void writeFields() const;
Thanks Henry for the solution.
Old   November 8, 2005, 10:37
Default My guess (but it's a long time
  #29
Assistant Moderator
Bernhard Gschaider
My guess (but it's a long time since I've worked with template specialisation):
Usually the Define NoRepository is set (for most architectures)
Because of this in Cloud.H includes Cloud.C and that includes CloudIO.C with the most general template.
Any source-code including Cloud.H (because he needs a declaration of Cloud to define his template spezialisation) finds the general case before the specialized template.
I think some compilers prefer the general case to the specialized in such situations (although Lord Stroustrup says that it doesn't matter). Could it be that gcc 4.0.1 (which I believe was distributed first with 1.2) has fallen back to this bad behaviour?
Old   November 10, 2005, 10:01
Default Sorry for my garbage. I didn't
  #30
Assistant Moderator
Bernhard Gschaider
Sorry for my garbage. I didn't read Niklas last posting.
Old   November 11, 2005, 06:08
Default Maybe it's not the right topic
  #31
Assistant Moderator
Bernhard Gschaider
Maybe it's not the right topic, but it fits to the course of this discussion:
As the dieselFoam-Solver is much too sophisticated for our purposes here I wrote a little demo-solver that only does some basic particle tracking (no evaporation etc).
It can be found at
http://openfoamwiki.net/index.php/Contrib_icoLagr angianFoam
It only serves as a demonstation and doesn't resemble the real world.
Old   November 13, 2005, 11:51
Default nice! So what are you using it
  #32
Mattijs Janssens
mattijs is on a distinguished road
nice! So what are you using it (lagrangian tracking) for?
mattijs is offline   Reply With Quote
Old   November 14, 2005, 06:09
Default Myself I'm not using it. I did
  #33
Assistant Moderator
Bernhard Gschaider
Myself I'm not using it. I did it as a feasability study for a colleague who plans to use it for a project for particle sprays and another with particle interception in a production process.
Old   January 20, 2006, 07:06
Default Hi, I try to fix the bug in
  #34
stefan
stefanke is on a distinguished road
I try to fix the bug in lagrangian lib according to this posting:
declare writeFields() and readFields() as virtual in src/lagrangian/basic/Cloud.H
Then I recompiled the liblagrangian and the dieselFoam solver as well.
When I try to calc the aachenBomb case (dieselFoam solver) there is only one file (positions) in the lagrangian directory! I think the workaround above should fix this problem?
Any help is very appreciated
stefanke is offline   Reply With Quote
Old   January 20, 2006, 07:39
Default And did you recompile dieselSp
  #35
niklas's Avatar
Niklas Nordin
And did you recompile dieselSpray?
Old   January 20, 2006, 13:41
Default yes I do! I recompile the f
  #36
stefan
yes I do!
I recompile the following
liblagrangian
libdieselSpray
and the solver dieselFoam
but there is no more data than position in the lagrangian directory!
Old   January 22, 2006, 10:48
Default Niklas, the problem with th
  #37
stefan
Niklas,
the problem with the "empty" (only postion file is present) lagrangian directory occurs only running the solver in parallel!
Old   January 23, 2006, 03:13
Default reconstructPar depends on Clou
  #38
niklas's Avatar
Niklas Nordin
reconstructPar depends on Cloud.H.
Did you recompile that code?
Old   January 23, 2006, 10:07
Default I recompiled the hole OpenFoam
  #39
stefan
I recompiled the hole OpenFoam!
Anyway the solver abosts in paralell after a certain time
It seems to be impossible to run dieselFoam or dieselEngineFoam in parallel!
Old   January 23, 2006, 14:20
Default Ive just tested dieselFoam on
  #40
niklas's Avatar
Niklas Nordin
Ive just tested dieselFoam on the aachenBomb case in parallel and it works.
dieselEngineFoam should also work (in principle).
The scania case you took from my page is a different matter.
That page is just my personal file transfer page and
if you take something without asking and it doesnt work you have yourself to blame.
I have never claimed it to work and there is a reason I didnt make the case public you know.
N
DieselFoam Spray Evaporation Continuity Error spv24 OpenFOAM Running, Solving & CFD 14 December 30, 2010 11:50
ERROR IN RUNNING THE FIRST EXAMPLE marhamat OpenFOAM Installation 8 August 27, 2006 05:13
FIDAP RUNNING ERROR "ERROR-DIR-NOT-EMPTY=145" BAOYU FLUENT 0 January 26, 2006 19:32
DieselFoam error turbulent dispersion adorean OpenFOAM Running, Solving & CFD 6 April 22, 2005 07:55
error while running UDF murthy FLUENT 1 October 22, 2001 06:02
