Multiphase flow and Phase change due to heat transferevaporation
Like Tree6Likes
Old   May 29, 2010, 21:34
Sandy Lee
sandy is on a distinguished road
Hi, why you not to try to combine compressibleInterFoam solver and some heatTransfer solver? I will try it too.
sandy is offline   Reply With Quote
Old   June 9, 2010, 10:54
bephi is on a distinguished road
hi at all!
at the moment i am doing some simulations of a flow through a piston valve. right now i achieved some good results with the simpleFoam solver including k-w-SST model for low velocities or volume rate respectively. but when the effect of cavitation sets in, my results donīt follow the measured ones. therefore I try to set up a simulation with a multi-phase-solver. I decided to use rasCavitatingFoam but I achieved just unphysical results. After I read that some more people have problems with this solver and a friedly guy showed me a comparison of solvers ( http://web.student.chalmers.se/group...PosterOFW5.pdf ) I thought I rather use interPhaseChangeFoam. Would you say this is a good decision? (1)
Unfortunately I wasnīt able to set up a case now because I always get errors.
I downloaded the dambreak case calculated with interPhaseChangeFoam but I am not exactly sure what I need to change besides BCs and values of nu and rho. Is there somethin else? (2)
at the inlet i define my velocity with fixedValue (0 0 -1.04), outlet has fixedValue with 476.2.
I heard that it would be good to use solutions from a converged calculation as starting values for the more complicated. But how can I do that? (3) After simpleFoam my resulting pressures are given in m^2/s^2 because of the density. interPhaseChangeFoam is compressilble and the pressure unit is Pa.
best wishes!
bephi is offline   Reply With Quote
Old   September 24, 2010, 15:02
Nima Samkhaniani
nimasam is on a distinguished road
hi buddies
could you please correct me if im wrong
first in phaseChangeTwoPhaseMixture::vDotAlphal() there is following expression
volScalarField alphalCoeff = 1.0/rho1() - alpha1_*(1.0/rho1() - 1.0/rho2());
but the source term in gamma equation is mdot/rhoLiquid , so how the above code can be right ?
second : why the following expression has been added in pEqn.H :
- (vDotvP - vDotcP)*pSat + fvm::Sp(vDotvP - vDotcP, p)
nimasam is offline   Reply With Quote
Old   February 24, 2012, 03:31
Default mDotAlphal() and mDotP() In interphasechange
  #84
vahid
vahid.najafi is an unknown quantity at this point
Hello OpenFoam users ,
I'mstudying on the Kunz model.we know in this model we have two term for mass dest and prod.(m+ and m-)
What mean mDotAlphal() and mDotP()In interphasechange?
What is the difference between these two??
lekeji likes this.
vahid.najafi is offline   Reply With Quote
Old   April 8, 2013, 08:19
abe
ABE
abe is on a distinguished road
I am using InterPhaseChange solver to simulate cavitation in OF2.1x
Although by old versions (i.e. OF1.5) I can get good results, with this new version results are not good at all. Dose anybody else get similar conflicts?
ABE
abe is offline   Reply With Quote
Old   April 8, 2013, 08:21
abe
ABE
ABE
Old   April 9, 2013, 03:49
abe
ABE
Originally Posted by Jason3beard View Post
If your simulation is incompressible, then, i think, you must try interPhaseChangeFoam
Hi, thx for your reply. I am using interPhaseChange solver. But I can not get results in OF2.1 or 2.2 versions
Old   July 30, 2017, 10:02
Alice
yangzhuan is on a distinguished road
Originally Posted by haghajani View Post
Dear all,
Why there is no solver in Multi-phase flow solver series, capable of handling phase change due to evaporation?
I want to simulate high pressures release of Liquid Hydrogen, which evaporates shortly (flash evaporation/its boiling Temperature is 22K), after releasing in to atmosphere and am investigating if the multiphase solvers can be helpful;
I am thinking to "interfoam" based solver capable of handling with two phase flow + evaporation.
Would you please let me know, where/How I should modify, if the idea feasible?
Any other suggestion, I will be thankful;
Hamed Aghajani
hamed (dot) aghajani (at) gmail (dot) com
Hi, I want to simulate LNG gasification in water. The temperature of LNG is -169 degrees, and the temperature of water is 25 degrees. Due to temperature difference, the LNG would be gasification. Could the interPhaseChangeFoam simulate this case?
yangzhuan is offline   Reply With Quote
Old   February 11, 2020, 09:00
Navid
navidamin is on a distinguished road
can someone please answer this question?
I am also wondering about the vDot terms in phasechange solvers of OF. where do they come from? I have found the analytical explanation for gas/liquid interface. but does should it also be considered for melting/solidification?
navidamin is offline   Reply With Quote
Modelling Supersonic TwoPhase Flow with Phase Change wes OpenFOAM Running, Solving & CFD 9 July 27, 2021 12:05
About phase change heat and mass transfer Michael FLUENT 2 February 13, 2011 02:49
Two phase flow with phase change Ahmad Al-Zoubi CFX 1 November 26, 2008 04:59
Two-phase flow in T-junction, multiphase of DPM? Tony FLUENT 2 July 8, 2008 02:26
how to deal with phase-change heat exchanger? cherry FLUENT 1 April 16, 2002 22:59
