Multiphase flow and Phase change due to heat transferevaporation
Like Tree6Likes
Old   March 22, 2009, 14:30
Default build instructions
  #21
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
first of all,
type in wclean to cleanup previous buid
mkraposhin is offline   Reply With Quote
Old   March 23, 2009, 06:18
Hamed Aghajani
haghajani is on a distinguished road
Dear Matvej,
Thanks again for replying
following errors issued;
lnInclude/basicThermo.H:In member function 'virtual Foam::volScalarFields& Foam::basicThermo:: p()':
lnInclude/basicThermo.H:126: error: invalid initialization of reference of type 'Foam::volScalarFields&' from expression of type 'const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>'
lnInclude/basicThermo.H:In member function 'virtual Foam::volScalarFields& Foam::basicThermo::h()':
lnInclude/basicThermo.H:141: error: invalid initialization of reference of type 'Foam::volScalarFields&' from expression of type 'const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>'
lnInclude/basicThermo.H:In member function 'virtual Foam::volScalarFields& Foam::basicThermo::e()':
lnInclude/basicThermo.H:186: error: invalid initialization of reference of type 'Foam::volScalarFields&' from expression of type 'const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>'
haghajani is offline   Reply With Quote
Old   March 23, 2009, 07:32
mkraposhin's Avatar
Matvey Kraposhin
1) What OpenFOAM version are you using? I'm using v. 1.4.1
2) What operating system? (OpenSuSE 10.3)
3) What g++ version? (4.2.1)
Old   March 23, 2009, 08:19
Hamed Aghajani
OpenFoam 1.5
OS: OpenSUSE 11
gcc version 4.3.1
Old   March 25, 2009, 06:48
Hamed Aghajani
Dear Matvej,
Have you got any idea, what the problem could be?
thanks,
Hamed
Old   March 25, 2009, 07:24
mkraposhin's Avatar
Matvey Kraposhin
hi, haghajani,
I'm sorry for late reply
i'll try installing OF 1.5 this week, then i'll try to compile solver for this version and report to you 29.03
Old   March 29, 2009, 12:02
Default cavitatingPimpleFoam for OpenFOAM 1.5
  #27
mkraposhin's Avatar
Matvey Kraposhin
Hi All!
Here is a link for source code of caviatingPimpleFoam solver for OpenFOAM 1.5
http://www.os-cfd.narod.ru/small_fil...leFoam_1.5.tgz
Old   April 3, 2009, 15:11
Hamed Aghajani
Dear Matvej,
Many thanks for updating the forum with you code;
Today I came to your code; after wclean & wmake, again I faced this error;
g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/hamed/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IcompressibilityModels/compressibilityModel -IgammaModels/gammaModel -IbaroThermo -I/home/hamed/OpenFOAM/OpenFOAM-1.5/src/transportModels -IaltCompressibleTurbModels/lnInclude -IlnInclude -I. -I/home/hamed/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/hamed/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC Make/linux64GccDPOpt/cavitatingPimpleFoam.o Make/linux64GccDPOpt/compressibilityModel.o Make/linux64GccDPOpt/newCompressibilityModel.o Make/linux64GccDPOpt/linear.o Make/linux64GccDPOpt/Wallis.o Make/linux64GccDPOpt/Chung.o Make/linux64GccDPOpt/gammaModel.o Make/linux64GccDPOpt/newGammaModel.o Make/linux64GccDPOpt/constant.o Make/linux64GccDPOpt/defaultGM.o Make/linux64GccDPOpt/SinghalMerkle.o Make/linux64GccDPOpt/Kunz.o Make/linux64GccDPOpt/Merkle.o Make/linux64GccDPOpt/baroThermo.o -L/home/hamed/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt \
-lfiniteVolume -L/home/hamed/OpenFOAM/hamed-1.5/lib/linux64GccDPOpt -lcompressibleAltTurbulenceModels -lOpenFOAM -liberty -ldl -lm -o /home/hamed/OpenFOAM/hamed-1.5/applications/bin/linux64GccDPOpt/cavitatingPimpleFoam
/usr/bin/ld: cannot find -lcompressibleAltTurbulenceModels
collect2: ld returned 1 exit status
make: *** [/home/hamed/OpenFOAM/hamed-1.5/applications/bin/linux64GccDPOpt/cavitatingPimpleFoam] Error 1
unfortunately, I couldn't find out the source;
Thanks,
Hamed
Old   April 3, 2009, 15:26
Default interPhaseChangeFoam tutorial
  #29
Hamed Aghajani
Dear all,
If your are going to work with interPhaseChangeFoam and you are looking for a tutorial, I have update the well-known dambreak case, and you can use of it to start;
Good Luck,
Hamed
Old   April 5, 2009, 04:16
mkraposhin's Avatar
Matvey Kraposhin
Go to directory altCompressibleTurbModels, type wclean and then wmake
Old   April 7, 2009, 10:25
Hamed Aghajani
Dear Matvej,
sorry to interrupt you too much,
but I wonder I can not make the solver;
following error has been raised;
Make/linux64GccDPOpt/mutStandardRoughWallFunctionFvPatchScalarField.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam:bjectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const':
mutStandardRoughWallFunctionFvPatchScalarField.C .text._ZNK4Foam14objectRegistry12lookupObjectINS_1 4GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEEE ERKT_RKNS_4wordE[Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam:bjectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const]+0x170): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::typeName'
mutStandardRoughWallFunctionFvPatchScalarField.C .text._ZNK4Foam14objectRegistry12lookupObjectINS_1 4GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEEE ERKT_RKNS_4wordE[Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam:bjectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const]+0x2c4): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::typeName'
make: *** [OpenFOAM.out] Error 1
best,
Hamed
Old   April 7, 2009, 16:11
mkraposhin's Avatar
Matvey Kraposhin
Can you post here all steps you are doing?
because i don't have mutStandardWallFunctions
Your information could be very useful, because some of my students experienced some problems with my solver, but i'm - not ^)
Old   April 7, 2009, 16:16
mkraposhin's Avatar
Matvey Kraposhin
actually, you should go to dir altCompressibleTurbModels and type 'wclean', then 'wmake libso'
then, you must go up and type
'wclean; wmake'
Old   April 8, 2009, 07:18
Hamed Aghajani
Dear Matvej,
Thanks again,
it has been compiled.
best,
Hamed
Old   April 13, 2009, 09:56
Nugroho Adi
mahaputra is on a distinguished road
Dear mkraposhin
thanks for your new solver
do you hava a simple case for cavitatingPimpleFoam?
or could you please show us how to build a new file so called constant/thermodynamicPr ? based on :
Info<< "Reading thermodynamicProperties\n" << endl;
IOdictionary thermodynamicProperties
IOobject
"thermodynamicProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
dimensionedScalar psil(thermodynamicProperties.lookup("psil"));
dimensionedScalar rholSat(thermodynamicProperties.lookup("rholSat")) ;
dimensionedScalar psiv(thermodynamicProperties.lookup("psiv"));
dimensionedScalar pSat(thermodynamicProperties.lookup("pSat"));
dimensionedScalar rhovSat("rhovSat", psiv*pSat);
dimensionedScalar rhol0("rhol0", rholSat - pSat*psil);
Info << "rhol0 - " << rhol0 << endl;
dimensionedScalar rhoMin(thermodynamicProperties.lookup("rhoMin"));
many thanks
mahaputra is offline   Reply With Quote
Old   April 15, 2009, 11:48
mkraposhin's Avatar
Matvey Kraposhin
You can use thermodynamicProperties file from rasCavitatingFoam (or cavitatingFoam) solver tutorial
Old   April 15, 2009, 14:45
Nugroho Adi
Dear Matvej
thanks for the information
anyway , what about the keyword gammaModel ? since it is undefined in dictionary of thermodynamicProperties ?
how should i modifiy the gammaModel?
Old   April 16, 2009, 11:56
Default Cavitation solver
  #38
mkraposhin's Avatar
Matvey Kraposhin
Dear friends!
I found some errors in the code of my solver. I'll fix them till 19.04.2009. Then, i'll put links to test cases and updated code on this thread.
Old   May 5, 2009, 11:53
Hamed Aghajani
Dear Matvej,
Have you updated the code/Test cases?
Please update the tread with your comments
Best regards,
Hamed
Old   May 7, 2009, 07:52
Hamed Aghajani
Dear All,
How can I trace the vaporized liquid (changed phase from 1->0) in to air.
I am trying to study the effect of flash evaporation in high pressure liquid Hydrogen release. I used interPhaseChangeFoam for a simple case and the results seems reasonable. Now I want also see the vapor of hydrogen inside surrounding air.
Best regards,
Hamed Aghajani
hamed.aghajani@gmail.com
h.aghajani@kingston.ac.uk
Modelling Supersonic TwoPhase Flow with Phase Change wes OpenFOAM Running, Solving & CFD 9 July 27, 2021 12:05
About phase change heat and mass transfer Michael FLUENT 2 February 13, 2011 02:49
Two phase flow with phase change Ahmad Al-Zoubi CFX 1 November 26, 2008 04:59
Two-phase flow in T-junction, multiphase of DPM? Tony FLUENT 2 July 8, 2008 02:26
how to deal with phase-change heat exchanger? cherry FLUENT 1 April 16, 2002 22:59
