SpalartAllmaras question
Like Tree2Likes
Old   March 16, 2009, 10:17
Philippe B. Vincent
philippebv is on a distinguished road
Daniel, it's awesome that you got results with DES and DDES for
channelOodles. What does it look like? Is the RANS region increased in
DDES? For IDDES, I personally have no interest in it since it's for
WMLES. But I would be glad to see if it helps with log layer mismatch.
For the boundary conditions, I have had a few concerns about them, and
I'm not quite sure that I impose nuTilda and nuSgs correctly. I ran
cases using, at the inlet, a Dirichlet condition for nuTilda and a
Neumann condition for nuSgs and it worked fine:
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class volScalarField;
object nuTilda;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0.0000693426;
boundaryField
inlet
type fixedValue;
value uniform 0.0000693426; // nu_t/nu = 1
outlet
type inletOutlet;
inletValue uniform 0;
value uniform 0;
wall
type fixedValue;
value uniform 0;
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
object nuSgs;
internalField uniform 1.5e-5;
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
wall
type zeroGradient;
Best regards,
Philippe
philippebv is offline   Reply With Quote
Old   March 20, 2009, 13:52
Default nuTilda and nut
  #42
Gerard Mouokue
gerado is on a distinguished road
hi Hrv,
I am struggling since one week to understand why nuTilda have to be set in some case where the SpalartAllmaras modell is not used.
After a deep look in the src of all turbulence models ,I have founded ,that nuTilda is only defined in SpalartAllmaras model
SpalartAllmaras: nuTilda = nut/nu;
KEpsilon: nut = Cmu*k^2 /epsilon;
why do I have to set nuTilda when for example the KEpsilon model is used. why all turbulence model have to solve the nuTilda equation?
kind regards
gerard
gerado is offline   Reply With Quote
Old   March 21, 2009, 10:13
lin
Hua Zen
lin is on a distinguished road
Originally Posted by gerado View Post
hi Hrv,
kind regards
gerard
I guess Hrv could not answer your question.At least I could not reproduce this problem.I do not need to solve nuTilda when using kepsilon model.
lin is offline   Reply With Quote
Old   April 25, 2010, 08:16
Default different dimentions
  #44
Aldo Iannetti
aldo.iannetti is on a distinguished road
Hi
can you explane me the meaning of this error?
LHS and RHS of + have different dimensions
dimensions : [0 2 -2 0 0 0 0] + [1 -1 -2 0 0 0 0]
I got it in launching interDyMFoam in OF 1.5-dev,
It is a bug? how to fix it? I read I have (maybe) to recompile the solver, can you help me?
Thanks
Aldo
aldo.iannetti is offline   Reply With Quote
Old   April 26, 2010, 04:02
matej forman
matejfor is on a distinguished road
That one I know!
the error clearly statest, your LHS and RHS have different dimensions, namely:
LHS has dimension of: m^2/s^2
and RHS has dimenstions of: kg/m/s^2. You don't need to recompile anything, only to check the dimensions of variables in your 0 directory. Once you set this properly, everything will run fine. There's also possibility to turn-off the dimension check, but it's not a good idea at all.
good luck
matej
matejfor is offline   Reply With Quote
Old   October 28, 2010, 04:30
Manuel Goller
goma is on a distinguished road
Hi at all
I have a similar problem. I want to solve a simpleFoam case with SpalartAllmaras. Can someone help me with this error?!
incompatible dimensions for operation
[U[0 1 -2 0 0 0 0] ] == [-grad(p)[1 -2 -2 0 0 0 0] ]
If I set up the case with an comressible solver (rhoPisoFoam) the error is similar.
thx
goma is offline   Reply With Quote
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 23:43
Bug in SpalartAllmaras seb62 OpenFOAM Bugs 39 May 30, 2012 15:25
SpalartAllmaras DES question ivan_cozza OpenFOAM Running, Solving & CFD 0 December 15, 2008 07:34
YPlus for SpalartAllmaras ddigrask OpenFOAM Running, Solving & CFD 1 December 12, 2008 15:29
Pow in lib64tlslibmso6 SigFpe when running coodles with SpalartAllmaras lillberg OpenFOAM Bugs 4 December 7, 2007 09:17
