Example of use of the solidParticlesolidParticleCloud classes
Like Tree4Likes
Old   April 21, 2009, 07:50
Håkan Nilsson
hani is on a distinguished road
The dieselSpray classes have an injector implementation. Have a look there. There is no such in the very simple solidParticle class.
Also have a look at icoLagrangianFoam, which probably has it.
Håkan.
hani is offline   Reply With Quote
Old   June 10, 2009, 09:52
Default simpleLagrangianFoam
  #22
ZHOU Bin
Location: Nanjing/Torino, Nanjing/Piemente, China/Italy
zhoubinwx is on a distinguished road
Send a message via ICQ to zhoubinwx Send a message via MSN to zhoubinwx Send a message via Skype™ to zhoubinwx
Hi Håkan,
Thank you for a long-way help.
As I could see there is something not correct in icoLagrangianFoam solver, I derived the particle movement, and with my steady state flow field by simpleFoam, I plan to inject particle. Now I developed my simpleLagrangianFoam solver, which could fulfill my idea.
I have 2 questions to anybody who has experience with lagrangian:
1. Do we consider the particle diameter when particle hits the wall?
This is important, and I am thinking about this problem, if you have some suggestions, welcome.
2. How to get the concentration of particle in the air?
I have an idea:
set one sampling plane upstream, to see at each second, how many particles are through, say n_up(particles/second), with the mean air velocity v_up m/s and cross section A (m^2), we know the upstream concentration (n_up/(v_up*A), particles/m^3 at each second);
The problem is whether I can do this by OF 1.5.x?
If anyone who has problem about particles, welcome for discussion.
Best regards,
Bin
zhoubinwx is offline   Reply With Quote
Old   June 11, 2009, 04:09
Håkan Nilsson
Hi Bin,
You need to implement an injector, since there is no such in the solidParticleCloud class. Have a look at dieselFoam.
Håkan.
Old   June 11, 2009, 06:21
ZHOU Bin
Hi Håkan,
simpleLagrangianFoam solver is developed, which could model the particle movement in the steady-state flow field.
I will learn if in dieselFoam they consider the particle diameter when hitting the wall. If yes, I will include this in my solver.
I could see that my solver could only inject one particle at one time step, I have no idea how could I inject 2 or more particles at one time step.
Welcome comment or suggestions.
I am also practicing dieselFoam now, hoping to find something.
Bin
Old   June 16, 2009, 03:29
ZHOU Bin
Hi Foamers,
The two problems are solved. Again my concern is:
Method 1:
Method 2:
set one "box", to see how many particles are in this "box", and calculate the concentration.
The problem is I don't know how can I set this kind of plane/box to count the particles.
Thinking...
Bin
Old   June 17, 2009, 06:06
ZHOU Bin
Hello, dear Foamers,
After one day's work, I still can not find a way to define the concentration.
My purpose is to: define the efficiency of the cylinder capturing particles.
I set to generate 3 particles every time step, now let's see the log:
Moving Particles
2000 Particles moved. 0 walls hit. 4 particles left the model. 3 particles injected.
As we could see that the number of particles left the model > the number of particles injected. It seems strange, but it is so. Here I attach a pictures of my simple model, hoping some friends could give me some suggestions.
The efficiency is defined as: 1-C_out/C_in, where C_out is the downstream concentration, and C_in is the upstream concentration.
Thanks for attention.
Bin
Old   June 17, 2009, 23:04
Default Calculate DPM concentration in each cell
  #27
ZHOU Bin
Dear Foamers,
For my above problem, in the solver file, after we move the particles, we have already got "(x,y,z) cell" in the "positions" file.
Idea:
Can we include one file, which can calculate the particle numbers, then particle concentration at each cell from the "positions" file?
Algorithm:
1. generate a label list (1 1 1 .....1) like cell.size();
2. read the positions file, get the first cell index, sum those in the same cell, we get the particle numbers NP in this first cell, then we get the cell volume, i.e. mesh.V()[cellID], so we know the concentration NP/mesh.V()[cellID]; at the same time, give the corresponding cell label 0 instead of 1;
3. go to the second cell, if the label is 0, go the third cell; if not, do as 2;
4. until the end of positions file, we set the rest cell concentration to be 0;
5. in this way, we may sample or use areaAverage get the concentration of some plane;
I have this idea, but I am not sure if this is right or not? I have problem coding, if some one could do me a favor, really appreciate.
Bin
Alaska1964 likes this.
Old   July 9, 2009, 04:00
Default Brownian motion of sub-micro particles
  #28
ZHOU Bin
Dear Foamers,
I have made a code for the Brownian motion of sub-micro particles, but I need someone who is willing to test it.
If who is interested in this, please add my skype or msn.
Bin
Old   June 5, 2017, 04:23
Post Error in running case with icolagrangianFoam solver
  #29
AJAY BHANDARI
AJAY BHANDARI is on a distinguished road
Hi all,
I have coupled icoFoam solver with solidparticleCloud and made a new solver named icolagrangianFoam in openFoam 2.4.0 according to the following tutorial.
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2016/EbrahimGhahramani/Report_Ghahramani.pdf
I have modified the inject function according to this tutorial. And for the time being i have used one way coupling only.
My solver compiled with no error but when i am running the case with it it is showing the following error.
  Starting time loop
Time = 0.005
Courant Number mean: 0 max: 0
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 1.15856e-07, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG:  Solving for p, Initial residual = 1, Final residual = 2.96221e-07, No Iterations 36
time step continuity errors : sum local = 5.93837e-13, global = -1.56066e-22, cumulative = -1.56066e-22
DICPCG:  Solving for p, Initial residual = 0.000368734, Final residual = 7.38895e-07, No Iterations 26
time step continuity errors : sum local = 3.31228e-12, global = 4.415e-22, cumulative = 2.85434e-22
Cloud size = 0
ExecutionTime = 0.01 s  ClockTime = 0 s
Time = 0.01
Courant Number mean: 4.31471e-05 max: 0.000359491
smoothSolver:  Solving for Ux, Initial residual = 0.327035, Final residual = 3.07967e-08, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.333302, Final residual = 4.59868e-08, No Iterations 1
DICPCG:  Solving for p, Initial residual = 0.106629, Final residual = 6.59909e-07, No Iterations 30
time step continuity errors : sum local = 3.3037e-12, global = -5.31932e-22, cumulative = -2.46498e-22
DICPCG:  Solving for p, Initial residual = 2.11117e-05, Final residual = 9.80283e-07, No Iterations 4
time step continuity errors : sum local = 5.38914e-12, global = -3.36608e-22, cumulative = -5.83106e-22
Cloud size = 0
Time = 0.015
Courant Number mean: 8.62474e-05 max: 0.000718761
smoothSolver:  Solving for Ux, Initial residual = 0.195492, Final residual = 1.76912e-08, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.200906, Final residual = 2.62192e-08, No Iterations 1
DICPCG:  Solving for p, Initial residual = 0.0640431, Final residual = 6.19957e-07, No Iterations 29
time step continuity errors : sum local = 3.64984e-12, global = 1.79896e-22, cumulative = -4.0321e-22
DICPCG:  Solving for p, Initial residual = 1.37856e-05, Final residual = 9.41422e-07, No Iterations 3
time step continuity errors : sum local = 5.88669e-12, global = 6.20951e-22, cumulative = 2.17741e-22
Cloud size = 0
Time = 0.02
Courant Number mean: 0.000129306 max: 0.00107781
smoothSolver:  Solving for Ux, Initial residual = 0.13947, Final residual = 2.20727e-08, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.143906, Final residual = 1.78422e-08, No Iterations 1
DICPCG:  Solving for p, Initial residual = 0.0447785, Final residual = 7.94408e-07, No Iterations 28
time step continuity errors : sum local = 5.22257e-12, global = -1.45177e-21, cumulative = -1.23403e-21
DICPCG:  Solving for p, Initial residual = 1.11154e-05, Final residual = 6.92867e-07, No Iterations 3
time step continuity errors : sum local = 4.7462e-12, global = 1.12994e-21, cumulative = -1.04084e-22
Cloud size = 1
Time = 0.025
Courant Number mean: 0.000172327 max: 0.00143665
smoothSolver:  Solving for Ux, Initial residual = 0.108438, Final residual = 2.75195e-08, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.112097, Final residual = 1.37583e-08, No Iterations 1
DICPCG:  Solving for p, Initial residual = 0.0341882, Final residual = 7.60475e-07, No Iterations 28
time step continuity errors : sum local = 5.38762e-12, global = 1.15078e-21, cumulative = 1.0467e-21
DICPCG:  Solving for p, Initial residual = 9.32068e-06, Final residual = 7.5951e-07, No Iterations 2
time step continuity errors : sum local = 5.56977e-12, global = 1.80962e-21, cumulative = 2.85632e-21
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  double Foam::particle::trackToFace<Foam::solidParticle::trackingData>(Foam::Vector<double> const&, Foam::solidParticle::trackingData&) at ??:?
#4  Foam::solidParticle::move(Foam::solidParticle::trackingData&, double) at ??:?
#5  void Foam::Cloud<Foam::solidParticle>::move<Foam::solidParticle::trackingData>(Foam::solidParticle::trackingData&, double) at ??:?
#6  Foam::solidParticleCloud::move(Foam::dimensioned<Foam::Vector<double> > const&) at ??:?
#7  ? at ??:?
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9  ? at ??:?
Segmentation fault (core dumped)
From the terminal i am able to see that my particle is injected at time 0.02 sec as the cloud size becomes 1. But after that solver gives error.
I am attaching the case named cavitylagrangiannew also.
I don't know why the error is coming and i am not able to understand it.
I think there is some error in which i am setting up the case or something else of which i am not aware of.
Please help.
Regards
Ajay
cavitylagrangiannew.zip
AJAY BHANDARI is offline   Reply With Quote
Finite Area Classes and Surface related Utilities philippose OpenFOAM 10 December 9, 2011 12:42
Understanding tmp%2360T classes nadine OpenFOAM Running, Solving & CFD 14 January 22, 2009 10:25
Adding functionality to classes sergio OpenFOAM 9 March 13, 2008 06:18
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
