Difference between bubblefoam and twophaseeulerfoam
Old   January 15, 2008, 16:30
Default Hello, what is the differen
Enrico Bärow
ebaerow is on a distinguished road
what is the difference between those two? Both are based on H. Rusche, use Euler-Euler and k-epsilon.
I'm trying to solve a water flow with air being injected.
Although this might be an unsteady process is it possible to solve steady state (with one of these solver)?
Thanks!
Enrico
ebaerow is offline   Reply With Quote
Old   January 29, 2008, 12:51
Default I was told that twoPhaseEulerF
sek
Sung-Eun Kim
sek is on a distinguished road
I was told that twoPhaseEulerFoam has some additional models that allow granular flows. bubbleFoam came forst, and twoPhaseEulerFoam, an extended version came later.
sek is offline   Reply With Quote
Old   February 3, 2008, 09:12
Default Thanks! So I thing both will
Enrico Bärow
Thanks!
So I thing both will be suitable for my problem..
Old   March 14, 2009, 07:55
Default Hi..Enrico Barow and others
Raghavendra
raagh77 is on a distinguished road
Send a message via Yahoo to raagh77 Send a message via Skype™ to raagh77
my task is to simulate air particle being injected (at the center) to the water as continuous medium. (Becker case)
(Domain being simple 2D rectangular region sides and bottom (except at the center) being walls. Velocity inlet at the center and pressure outlet at the top)
Boundary conditions
1) alpha 0 gradients at the wall
2) inlet uniform 1
3) 3/4 th water (continous phase) filled so alpha being eual to 0 and remaining 1/4 air(discrete phase) and alpha being 1
4) alpha being 1 at the "top" where pressure outlet boundary conditions are set
top
type inletOutlet;
inletValue uniform 1;
value uniform 1;
5) at the inlet region alpha being 1
velocity-inlet
type fixedValue;
value uniform 1;
am using twoPhaseEulerFoam solver also I would like to know which could be the best solver when compare with bubbleFoam (turbulence being on)
Simulation errors:
When I try with these boundary conditions for alpha and with 0.9 m/s velocity at the inlet (air velocity) diameter of the particle being 0.00003 m
after few iterations courant number increase (around thousands!!) though the grid is not that fine also very small time step being employed.
Finally simulation crashes :-(
I want to know whether boundary conditions are to be altered or there I have to modify the solver and recompile again!!??
Awaiting for replies!
Regards
Raghavendra
raagh77 is offline   Reply With Quote
KEpsilon in bubbleFoam and twoPhaseEulerFoam vkaufmann OpenFOAM Running, Solving & CFD 0 November 5, 2008 09:25
Lift force modeling in bubbleFoam holger_marschall OpenFOAM Running, Solving & CFD 2 December 10, 2007 16:24
CVMcoefficient in bubblefoam stephan OpenFOAM Running, Solving & CFD 4 December 19, 2006 02:48
BubbleFoam alpha equation alberto OpenFOAM Running, Solving & CFD 9 September 21, 2005 02:33
Multiphase flow in bubbleFoam case brahim OpenFOAM Running, Solving & CFD 2 July 25, 2005 15:07
