Hydrostatic Pressure and Gravity
Like Tree4Likes
Old   April 11, 2010, 21:42
Alex
Alexvader is on a distinguished road
Hi Juliuslein
Thanks for your answer
alex@iskandhar:~/OpenFOAM/alex-1.6/Breeder_1.6/shipHydrodynamicIG/tutorials/shipFoam/roll$ ls
0  Allrun  VTK  constant  log.blockMesh  log.foamToVTK  log.setFields  log.shipFoam  log.snappyHexMesh  system
alex@iskandhar:~/OpenFOAM/alex-1.6/Breeder_1.6/shipHydrodynamicIG/tutorials/shipFoam/roll$ cat constant/polyMesh/boundary
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
2
    Walls
        type            patch;
        nFaces          11725;
        startFace       269150;
    Top
        type            patch;
        nFaces          1225;
        startFace       280875;
How do you suggest I change this file...?
I am quite an OpenFOAM n00b... all I know is from reading the PDF's from the workshops....
And by what i have seen... I've still got a long way to go...
Can this solver be used to simulate aerodynamic rigid motion instability in incompressible flow regime ( a subsonic twin engine aircraft in a single engine failure condition, for instance )...?
BRGDS
Alex
Alexvader is offline   Reply With Quote
Old   April 12, 2010, 05:51
Julius
juliuslein is on a distinguished road
Hi Alexvader,
depending on your case there are 2 possibilities:
1. Rename the patch "walls" to "hull" (the one that was requested by the solver for the dynamic mesh, found in dynamicMeshDict)
2. Change the name of the moved patch in the dynamicMeshDict to "walls", then the solver will find it
If you already modified all the occurrences of hull in the "0" directory I would prefer the first solution.
Good luck, Julius
juliuslein is offline   Reply With Quote
Old   April 12, 2010, 10:21
Alex
Hi JuliusLein
I will try this...
There is something strange though... :
checkMesh says Hull_region0 exists in my mesh :
alex@iskandhar:~/OpenFOAM/alex-1.5.x/openfoam-extend/shipFoamDemos/roll$ checkMesh
|  \\    /   O peration     | Version:  1.5.x                                 |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
Exec   : checkMesh
Date   : Apr 12 2010
Time   : 14:01:32
Host   : iskandhar
PID    : 4622
Case   : /home/alex/OpenFOAM/alex-1.5.x/openfoam-extend/shipFoamDemos/roll
nProcs : 1
Create time
Create polyMesh for time = constant
Time = constant
Mesh stats
    faces:            282100
    internal faces:   269150
    cells:            91875
    boundary patches: 2
    point zones:      0
    face zones:       0
    cell zones:       1
Number of cells of each type:
    hexahedra:     91875
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Point usage OK.
    Upper triangular ordering OK.
    Topological cell zip-up check OK.
    Face vertices OK.
    Face-face connectivity OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points    Surface
    Walls               11725    11796     ok (not multiply connected)
    Hull                1225     1296      ok (not multiply connected)
Checking geometry...
    Domain bounding box: (-3 -3 -3) (3 3 2)
    Boundary openness (7.22458e-16 7.65537e-17 1.10227e-17) OK.
    Max cell openness = 1.51788e-16 OK.
    Max aspect ratio = 2.57143 OK.
    Minumum face area = 0.0114286. Maximum face area = 0.0293878.  Face area magnitudes OK.
    Min volume = 0.00195918. Max volume = 0.00195918.  Total volume = 180.  Cell volumes OK.
    Mesh non-orthogonality Max: 0 average: 0
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 4.53341e-14 OK.
    All angles in faces OK.
    Face flatness (1 = flat, 0 = butterfly) : average = 1  min = 1
    All face flatness OK.
Mesh OK.
--> FOAM Warning :
    From function polyMesh::readUpdateState polyMesh::readUpdate()
    in file meshes/polyMesh/polyMeshIO.C at line 205
    Number of patches has changed.  This may have unexpected consequences.  Proceed with care.
Time = 0.001
Mesh stats
    faces:            357977
    internal faces:   338527
    cells:            113945
    boundary patches: 3
    point zones:      0
    face zones:       0
    cell zones:       1
    hexahedra:     108799
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     5146
    Point usage OK.
    Face vertices OK.
    Top                 1225     1296      ok (not multiply connected)
    Hull_region0        6500     6718      ok (closed singly connected surface)
    Boundary openness (-2.24025e-16 -3.70559e-17 2.59882e-17) OK.
    Max cell openness = 2.27681e-16 OK.
    Max aspect ratio = 2.57175 OK.
    Minumum face area = 0.00017856. Maximum face area = 0.0293893.  Face area magnitudes OK.
    Min volume = 3.82617e-06. Max volume = 0.00195938.  Total volume = 179.75.  Cell volumes OK.
    Mesh non-orthogonality Max: 50.4794 average: 6.82892
    Face pyramids OK.
    Max skewness = 0.999953 OK.
Mesh OK.
Time = 0.002
Mesh stats
    faces:            357977
    cells:            113945
    boundary patches: 3
    point zones:      0
    face zones:       0
    cell zones:       1
    hexahedra:     108799
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     5146
    Point usage OK.
    Face vertices OK.
    Boundary openness (-2.24264e-16 -3.74502e-17 2.63455e-17) OK.
    Max cell openness = 2.69775e-16 OK.
    Max aspect ratio = 3.53315 OK.
    Minumum face area = 5.65956e-05. Maximum face area = 0.0294002.  Face area magnitudes OK.
    Min volume = 2.68918e-06. Max volume = 0.00196592.  Total volume = 179.744.  Cell volumes OK.
    Mesh non-orthogonality Max: 53.9665 average: 7.07718
    Face pyramids OK.
    Max skewness = 1.63149 OK.
   *There are 4 faces with concave angles between consecutive edges. Max concave angle = 64.1358 degrees.
  <<Writing 4 faces with concave angles to set concaveFaces
    Face flatness (1 = flat, 0 = butterfly) : average = 0.999942  min = 0.898383
Mesh OK.
End
Yet it cannot be found in any file of directory 0.002, or in any directory of roll testcase whatsoever.... :
alex@iskandhar:~/OpenFOAM/alex-1.5.x/openfoam-extend/shipFoamDemos/roll$ grep -nH 'Hull_region0' 0.002/*
alex@iskandhar:~/OpenFOAM/alex-1.5.x/openfoam-extend/shipFoamDemos/roll$ grep -nH 'Hull' 0.002/*
0.002/cellLevel:113983:    Hull
0.002/meshPhi:350294:    Hull
0.002/pointLevel:130536:    Hull
alex@iskandhar:~/OpenFOAM/alex-1.5.x/openfoam-extend/shipFoamDemos/roll$ ls
0  0.001  0.002  Hull_motion.txt  constant  system
alex@iskandhar:~/OpenFOAM/alex-1.5.x/openfoam-extend/shipFoamDemos/roll$ grep -nH 'Hull' constant/*
constant/dynamicMeshDict:35:diffusivity  inverseDistance 1(Hull);
constant/dynamicMeshDict:37:// diffusivity  quadratic inverseDistance 1(Hull);
constant/dynamicMeshDict:38:// diffusivity  exponential 2000 inverseDistance 1(Hull);
constant/shipDict:27:   Hull
alex@iskandhar:~/OpenFOAM/alex-1.5.x/openfoam-extend/shipFoamDemos/roll$ grep -nH 'Hull_region0' constant/*
alex@iskandhar:~/OpenFOAM/alex-1.5.x/openfoam-extend/shipFoamDemos/roll$ grep -nH 'Hull' system/*
system/snappyHexMeshDict:39:    Hull
system/snappyHexMeshDict:108:        Hull
system/snappyHexMeshDict:178:   Hull
alex@iskandhar:~/OpenFOAM/alex-1.5.x/openfoam-extend/shipFoamDemos/roll$ grep -nH 'Hull_region0' system/*
I thought I had replaced Hull_region0 by Hull in every occurrence... yet shipFoam misses it, and checkMesh says it really exists in my mesh....
Is this sort of Hardcoded in any binary...?
I think I will change all my "Hull"s back to "Hull_region0"s in the roll case ... but this is really weird, even using nano and ctrl-W to find this Hull_region0 reports nothing... how come...?
BRGDS
Alex
Old   May 4, 2010, 05:28
John Wang
cwang5 is on a distinguished road
Hi guys,
I'm wondering if there's a version of the code for shipFoam that would work in OF-1.6? Thanks.
John
cwang5 is offline   Reply With Quote
Old   November 10, 2010, 07:41
Ralph Moolenaar
Ralph M is on a distinguished road
Hello all,
I'm trying to compile shipFoam under OF 1.7.1. I had to change some of the directories but I got an error which I don't understand:
EDIT: I got a version of shipFoam from http://openfoam-extend.svn.sourcefor...ydrodynamicIG/
It seems to work under 1.6 (gamma is changed into alpha1) but some work has to be performed to get it right for 1.7.1.
After changing p into p_rgh and changing some other files the wmake process goes well. However, when I run shipFoam I got the following error:
Spring coefficients are updated every 10 timesteps.
Selecting ODE solver RK
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.0011976
Time = 0.0011976
DICPCG: Solving for cellMotionUx, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for cellMotionUy, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for cellMotionUz, Initial residual = 0, Final residual = 0, No Iterations 0
Execution time for mesh.update() = 2.33 s
time step continuity errors : sum local = 0, global = 0, cumulative = 0
GAMGPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
MULES: Solving for alpha1
Liquid phase volume fraction = 0 Min(alpha1) = 0 Max(alpha1) = 0
smoothSolver: Solving for Ux, Initial residual = 0.999999, Final residual = 2.54205e-08, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.999999, Final residual = 2.53028e-08, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.999999, Final residual = 8.68022e-08, No Iterations 2
GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 6.14819e-07, No Iterations 19
GAMG: Solving for p_rgh, Initial residual = 0.142886, Final residual = 6.76717e-07, No Iterations 12
Relaxation: p_rgh = 0.2
time step continuity errors : sum local = 3.12128e-15, global = 1.5957e-15, cumulative = 1.5957e-15
GAMG: Solving for p_rgh, Initial residual = 0.240736, Final residual = 6.02055e-07, No Iterations 16
GAMG: Solving for p_rgh, Initial residual = 0.285422, Final residual = 6.55771e-07, No Iterations 13
time step continuity errors : sum local = 1.19739e-15, global = 6.0978e-16, cumulative = 2.20548e-15
GAMG: Solving for p_rgh, Initial residual = 0.171709, Final residual = 8.60057e-07, No Iterations 15
GAMGPCG: Solving for p_rgh, Initial residual = 0.209926, Final residual = 1.81723e-07, No Iterations 5
time step continuity errors : sum local = 3.61807e-16, global = -2.70325e-18, cumulative = 2.20278e-15
--> FOAM FATAL ERROR:
request for volScalarField p from objectRegistry region0 failed
available objects of type volScalarField are
11
K
rho
p_rgh
alpha1_0
nu
gh
nu1
rho_0
nu2
alpha1
p_rghPrevIter
From function objectRegistry::lookupObject<Type>(const word&) const
in file /opt/openfoam171/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 139.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/home/ralphmoolenaar/OpenFOAM/ralphmoolenaar-1.7.1/applications/bin/linuxGccDPOpt/shipFoam"
#3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam:bjectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const in "/home/ralphmoolenaar/OpenFOAM/ralphmoolenaar-1.7.1/applications/bin/linuxGccDPOpt/shipFoam"
#6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Aborted
I can't find a source for the problem, where do I have to look?
Regards,
Ralph
Ralph M is offline   Reply With Quote
Old   November 13, 2010, 08:41
Ralph Moolenaar
I already solved the problem; in some of the files there was still a reference to "p". The solver is now running smoothly, although I have some questions about the shipDict.
1) What is Amax
2) How is the damping defined? is it a number between 0 and 1?
3) What is the "weightFactor" supposed to do?
Old   November 19, 2010, 10:59
Ralph Moolenaar
Hello all,
1) What is Amax
-->maximum acceleration (duh)
--> this number is multiplied with the specified unit
--> this is used to use the results from earlier calculations. 1st entry is weighting of current force/moment, 2nd of the previous time step and the 3rd entry of two timesteps ago.
The updated version of shipFoam can be found in the OF Ship Hydromechanics group http://www.cfd-online.com/Forums/gro...mechanics.html
Old   March 3, 2011, 13:14
Mark Beal
msbealo is on a distinguished road
MarkC (and others?)
I've just read through this thread and have a couple of questions.
I'm interested in simulating yacht hulls resistance and lift with 2DoF (pitch and heave). I've only just started but I was using interDyMFoam with dynamicMotionSolverFvMesh and sixDoFRigidBodyMotionConstraint.
1) What does shipFoam do that interDyMFoam does not?
2) Has interDyMFoam been updated since shipFoam was conceived?
3) If I'm trying to simulate a towing tank, what would be the best approach.
4) (Slightly related) Should I be using fixedValue or movingWallVelocity on my hull patch?
Kind Regards,
Mark
msbealo is offline   Reply With Quote
Old   March 3, 2011, 13:51
Ralph Moolenaar
Hello Mark,
1) The problem with interDyMFoam is that for some cases the pressure explodes. therefore shipFoam is developed; is does the same as interDyMFoam but uses a weighted pressure from (i think) previous time steps. In this way the solver is more stable. ShipFoam was first developed for OF 1.5 (dev?) but I tried to rewrite it for OF 1.7. I think there are still some issues with the pressure but at the moment I don't have time to finish this.
2) I don't know
3) That depends on your problem. If you are looking for steady state trim/sinkage I think it is the easiest way to keep the ship fixed in flow direction and to let the water have a velocity.
4) I would use buoyantPressure for the pressure patch and for the velocity
type movingWallVelocity;
value uniform (0 0 0);
Cheers,
Ralph
CFD for marine applications? Go to http://www.marinecfd.com/ and join the OF Ship Hydromechanics Group: http://www.cfd-online.com/Forums/gro...mechanics.html
Old   March 8, 2011, 07:26
Default problem compiling
  #130
Francisco Miguel
Curro5150 is on a distinguished road
Hello, I am trying to do some multiphase ship hydrodynamics tests, and would like to try the shipFoam as I think it could save me quite a bit of work. However, I managed to compile the waveBC and the setHydrostatics on 1.6-ext, but I am having problems with the shipFoam solver. I tried to compile the ODE solver from 1.5, as suggested above, but it won't compile, most likely due to the different OF versions. Still, the error seems to be related with the ODE solver. Any clues/suggestions? Below you can find what I am getting:
Making dependency list for source file rotationMatrix/rotationMatrix.C
Making dependency list for source file motionODE/motionODE.C
Making dependency list for source file bodyMotion/bodyMotion.C
Making dependency list for source file writeMotionFile/writeMotionFile.C
Making dependency list for source file shipFoam.C
SOURCE=rotationMatrix/rotationMatrix.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/applications/solvers/multiphase/interFoam -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels/incompressible/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels/interfaceProperties/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/turbulenceModel -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicMesh/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicFvMesh/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/sampling/lnInclude -I/home/cfd02/OpenFOAM/cfd02-1.6-ext/applications/solvers/ODE2/lnInclude -IrotationMatrix -ImotionODE -IbodyMotion -IwriteMotionFile -IlnInclude -I. -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/rotationMatrix.o
SOURCE=motionODE/motionODE.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/applications/solvers/multiphase/interFoam -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels/incompressible/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels/interfaceProperties/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/turbulenceModel -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicMesh/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicFvMesh/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/sampling/lnInclude -I/home/cfd02/OpenFOAM/cfd02-1.6-ext/applications/solvers/ODE2/lnInclude -IrotationMatrix -ImotionODE -IbodyMotion -IwriteMotionFile -IlnInclude -I. -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/motionODE.o
SOURCE=bodyMotion/bodyMotion.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/applications/solvers/multiphase/interFoam -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels/incompressible/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels/interfaceProperties/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/turbulenceModel -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicMesh/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicFvMesh/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/sampling/lnInclude -I/home/cfd02/OpenFOAM/cfd02-1.6-ext/applications/solvers/ODE2/lnInclude -IrotationMatrix -ImotionODE -IbodyMotion -IwriteMotionFile -IlnInclude -I. -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/bodyMotion.o
SOURCE=writeMotionFile/writeMotionFile.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/applications/solvers/multiphase/interFoam -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels/incompressible/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels/interfaceProperties/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/turbulenceModel -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicMesh/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicFvMesh/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/sampling/lnInclude -I/home/cfd02/OpenFOAM/cfd02-1.6-ext/applications/solvers/ODE2/lnInclude -IrotationMatrix -ImotionODE -IbodyMotion -IwriteMotionFile -IlnInclude -I. -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/cfd02/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/writeMotionFile.o
In file included from bodyMotion/bodyMotion.C:28:
bodyMotion/bodyMotion.H:63: error: cannot declare field ‘Foam::bodyMotion:de’ to be of abstract type ‘motionODE’
motionODE/motionODE.H:42: note: because the following virtual functions are pure within ‘motionODE’:
/home/cfd02/OpenFOAM/cfd02-1.6-ext/applications/solvers/ODE2/lnInclude/ODE.H:71: note: virtual Foam::scalarField& Foam::ODE::coeffs()
/home/cfd02/OpenFOAM/cfd02-1.6-ext/applications/solvers/ODE2/lnInclude/ODE.H:74: note: virtual const Foam::scalarField& Foam::ODE::coeffs() const
/home/cfd02/OpenFOAM/cfd02-1.6-ext/applications/solvers/ODE2/lnInclude/ODE.H:94: note: virtual void Foam::ODE::update(Foam::scalar)
In file included from bodyMotion/forceBalance.H:64,
from bodyMotion/bodyMotion.C:118:
bodyMotion/motionCalc.H: In member function ‘void Foam::bodyMotion::forceBalance()’:
bodyMotion/motionCalc.H:39: error: no matching function for call to ‘Foam::ODESolver::solve(motionODE&, int, double&, Foam::scalarField&, Foam::scalar&, Foam::scalar&)’
/home/cfd02/OpenFOAM/cfd02-1.6-ext/applications/solvers/ODE2/lnInclude/ODESolver.H:117: note: candidates are: virtual void Foam::ODESolver::solve(Foam::scalar&, Foam::scalarField&, Foam::scalarField&, Foam::scalar, const Foam::scalarField&, Foam::scalar, Foam::scalar&, Foam::scalar&) const
/home/cfd02/OpenFOAM/cfd02-1.6-ext/applications/solvers/ODE2/lnInclude/ODESolver.H:130: note: virtual void Foam::ODESolver::solve(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar&) const
In file included from bodyMotion/forceBalance.H:94,
make: *** [Make/linuxGccDPOpt/bodyMotion.o] Error 1
make: *** Se espera a que terminen otras tareas....
Regards,
Francisco
Curro5150 is offline   Reply With Quote
Old   March 19, 2012, 12:14
Jan Löhrmann
JanL is on a distinguished road
I hope somebody is still following this thread as I do have exactly the same problem as in the post before by Francisco.
Does anybody have an answer on that problem?
Here is what I've done:
(1) I downloaded all files from this URL: http://openfoam-extend.svn.sourcefor...ydrodynamicIG/ and copied them into the folders in my OpenFoam-1.6-ext directory.
(2) Afterwards I went to /applications/solvers/shipFoam1.6.2 and typed wmake, which produced the same error as mentioned before.
(3) Then i tried to compile setHydrostatic with wmake which went through.
(4) At last I tried to compile waveBC which produced an error as dynamicFvMesh.H couldn't be found.
Can I simply copy the dynamicFvMesh from OF-1.5-dev e.g. into my OF-1.6-ext and compile it, so that waveBC has acces to this file? Does anybody know if that also solves the problem with the bodyMotion.o file as mentioned in the previous post when running wmake in the shipFoam-solver?
My original intention was to evaluate the shipFoam solver. Does anybody have more experience with this solver? Are there any papers about it (e.g. how does it perform against benchmarks, etc.)?
Best Regards
Jan
JanL is offline   Reply With Quote
Old   March 20, 2012, 03:26
Ralph Moolenaar
Dear Jan,
It has been a while since I used shipFoam for the last time. I think that your problems can be solved by changing the wmake files a bit; did you already had a look at the hydro-group (see link below in my signature)?
Furthermore I'm quit sure that no benchmarks have been performed for shipFoam. Can you send me a PM what you are planning to do and what your background is?
Cheers,
Ralph
Old   October 7, 2012, 23:50
Bob Zhang
bobzhang is on a distinguished road
Originally Posted by velan View Post
Dear Mark,
I have downloaded your source file and try to compile it. But i got the error message while compiling
[tetra@scram shipFoam]$ wmake
SOURCE=bodyMotion/bodyMotion.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/transportModels -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/transportModels/incompressible/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/transportModels/interfaceProperties/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/turbulenceModels/RAS -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/turbulenceModels/RAS/incompressible/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/dynamicMesh/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/meshTools/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/dynamicFvMesh/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/sampling/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/ODE/lnInclude -IrotationMatrix -ImotionODE -IbodyMotion -IwriteMotionFile -IlnInclude -I. -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/bodyMotion.o
SOURCE=shipFoam.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/transportModels -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/transportModels/incompressible/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/transportModels/interfaceProperties/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/turbulenceModels/RAS -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/turbulenceModels/RAS/incompressible/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/dynamicMesh/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/meshTools/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/dynamicFvMesh/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/sampling/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/ODE/lnInclude -IrotationMatrix -ImotionODE -IbodyMotion -IwriteMotionFile -IlnInclude -I. -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/shipFoam.o
In file included from bodyMotion/bodyMotion.C:1:
bodyMotion/bodyMotion.H:43: error: cannot declare field ‘Foam::bodyMotion:de’ to be of abstract type ‘motionODE’
motionODE/motionODE.H:14: note: because the following virtual functions are pure within ‘motionODE’:
/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/ODE/lnInclude/ODE.H:71: note: virtual Foam::scalarField& Foam::ODE::coeffs()
/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/ODE/lnInclude/ODE.H:74: note: virtual const Foam::scalarField& Foam::ODE::coeffs() const
/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/ODE/lnInclude/ODE.H:94: note: virtual void Foam::ODE::update(Foam::scalar)
In file included from bodyMotion/forceBalance.H:34,
from bodyMotion/bodyMotion.C:96:
bodyMotion/motionCalc.H:15: error: no matching function for call to ‘Foam::ODESolver::solve(motionODE&, int, double&, Foam::scalarField&, Foam::scalar&, Foam::scalar&)’
/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/ODE/lnInclude/ODESolver.H:126: note: candidates are: virtual void Foam::ODESolver::solve(Foam::scalar&, Foam::scalarField&, Foam::scalarField&, Foam::scalar, const Foam::scalarField&, Foam::scalar, Foam::scalar&, Foam::scalar&) const
/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/ODE/lnInclude/ODESolver.H:135: note: virtual void Foam::ODESolver::solve(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar&) const
In file included from bodyMotion/forceBalance.H:67,
In file included from shipFoam.C:64:
/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/readPISOControls.H: In function ‘int main(int, char**)’:
/home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/readPISOControls.H:3: warning: unused variable ‘nCorr’
make: *** Waiting for unfinished jobs....
make: *** [Make/linuxGccDPOpt/shipFoam.o] Error 1
Can you help me to get rid out these errors.
- Velan
hi velan,
i met the same problem, have you resolve it?
bobzhang is offline   Reply With Quote
hydrostatic pressure Amanda FLUENT 6 April 20, 2016 12:00
Hydrostatic pressure(rho*g*h) Pranesh FloEFD, FloWorks & FloTHERM 3 October 17, 2008 07:18
hydrostatic pressure multiphase FLUENT 0 May 18, 2003 16:16
Hydrostatic pressure in 5.5 Jens CFX 3 August 21, 2002 12:05
Hydrostatic Pressure Rhydar CFX 3 March 6, 2002 10:54
