November 4, 2008, 17:56 |
Dear Prof. Jasak,
Thanks alot
#21 |
Pal Schmitt
Rep Power: 17 |
Dear Prof. Jasak,
Thanks alot for Your answer! I assume You are refering to the GGI method, right? Should sliding interface work too? I have a two week old svn checkout and am struggling to make the world turn:-) GGI seems great and I tend to prefer it but still don't have any substantial experience, still learning about the world of OpenFOAM... And in both cases I haven't yet understood if I should use a wall or movingwall patch on the rotating item. Any hint appreciated.. Pal |
January 22, 2009, 09:59 |
Hi again,
After some successe
#22 |
Pal Schmitt
Rep Power: 17 |
Hi again,
After some successes I am stuck again. Using OpenFOAM 1.5-dev I get the following warning when using GGI in one of my cases: Starting time loop Volume: new = 3.86875 old = 3.86875 change = 0 ratio = 0 Courant Number mean: 0.00828238 max: 0.285853 deltaT = 0.0119048 Time = 8.5019 --> FOAM Warning : From function GGIInterpolation<masterpatch,>::calcAddressing() in file /data/tmp/dasch/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/GGIInterpolatio nWeights.C at line 346 polygonIntersection is returning a zero surface area between Master face: 1649 and Neighbour face: 928 intersection area = 0 Please check the two quick-check algorithms for GGIInterpolation. Something is missing. --> FOAM Warning : From function GGIInterpolation<masterpatch,>::calcAddressing() in file /data/tmp/dasch/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/GGIInterpolatio nWeights.C at line 346 polygonIntersection is returning a zero surface area between Master face: 1924 and Neighbour face: 1795 intersection area = 0 Please check the two quick-check algorithms for GGIInterpolation. Something is missing. --> FOAM Warning : From function GGIInterpolation<masterpatch,>::calcAddressing() in file /data/tmp/dasch/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/GGIInterpolatio nWeights.C at line 346 polygonIntersection is returning a zero surface area between Master face: 1940 and Neighbour face: 1765 intersection area = 0 Please check the two quick-check algorithms for GGIInterpolation. Something is missing. --> FOAM Warning : From function GGIInterpolation<masterpatch,>::calcAddressing() in file /data/tmp/dasch/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/GGIInterpolatio nWeights.C at line 346 polygonIntersection is returning a zero surface area between Master face: 1947 and Neighbour face: 1815 intersection area = 0 Please check the two quick-check algorithms for GGIInterpolation. Something is missing. Rescaling of weighting factor: Largest slave weighting factor correction : 0.0750979 Largest master weighting factor correction: 0.151511 PBiCG: Solving for Ux, Initial residual = 0.00135415, Final residual = 4.47234e-06, No Iterations 2 PBiCG: Solving for Uy, Initial residual = 0.0110796, Final residual = 2.34074e-06, No Iterations 3 PBiCG: Solving for Uz, Initial residual = 0.0110797, Final residual = 2.33857e-06, No Iterations 3 PCG: Solving for p, Initial residual = 0.606757, Final residual = 0.0281306, No Iterations 33 time step continuity errors : sum local = 2.18226e-06, global = -7.99789e-08, cumulative = -7.99789e-08 PCG: Solving for p, Initial residual = 0.102947, Final residual = 0.0049724, No Iterations 48 time step continuity errors : sum local = 5.21564e-07, global = 8.47932e-08, cumulative = 4.8143e-09 PCG: Solving for p, Initial residual = 0.0188893, Final residual = 0.000921721, No Iterations 87 time step continuity errors : sum local = 9.13106e-08, global = -6.33622e-10, cumulative = 4.18068e-09 PCG: Solving for p, Initial residual = 0.00395311, Final residual = 9.95545e-07, No Iterations 141 time step continuity errors : sum local = 1.02719e-10, global = -6.20499e-12, cumulative = 4.17447e-09 ExecutionTime = 9.27 s ClockTime = 10 s Sometimes my calculation stops with a floating point exception (but no more information) but when started again from last timestep is likely to keep working for some time. Checkmesh gives no error. Any hint wether these two are pure coincidence or is my mesh to bad. Otherwise the results seem OK. I can share the case if anyone cares to see it. Thanks in advance, Pal |
January 22, 2009, 10:02 |
Hi again,
After some successe
#23 |
Pal Schmitt
Rep Power: 17 |
Hi again,
January 22, 2009, 10:04 |
Hi again,
After some successe
#24 |
Pal Schmitt
Rep Power: 17 |
Hi again,
January 22, 2009, 10:10 |
Hi again,
After some successe
#25 |
Pal Schmitt
Rep Power: 17 |
Hi again,
January 22, 2009, 12:20 |
I have no idea - it works real
#26 |
Hrvoje Jasak
Rep Power: 33 |
I have no idea - it works really well over here. Try running a debug version and trace back the core to find out what happened.
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
January 22, 2009, 14:11 |
Please send your complete test
#27 |
Martin Beaudoin
Rep Power: 22 |
Please send your complete test case, including the content of your main OF_1.5-dev controlDict in order to see your tolerance factor values.
Martin |
January 22, 2009, 17:08 |
Hi Martin,
Thanks for Your he
#28 |
Pal Schmitt
Rep Power: 17 |
Hi Martin,
Thanks for Your help. I will send You everything next tuesday, please provide me with some information on where to send it... You can email me at pal . schmitt at tu - harburg . de without whitespaces:-) See You, Have a great weekend:-), Pal |
January 22, 2009, 22:02 |
Click on my name, the little b
#29 |
Martin Beaudoin
Rep Power: 22 |
Click on my name, the little blue string just above this sentence.
Martin |
January 23, 2009, 07:40 |
Hi all
I have a question co
#30 |
David Hora
Rep Power: 17 |
Hi all
I have a question concerning the correction vectors for GGI patches in OF-1.5-dev. In the current version a zero vector is returned for the correction vector. A different solution (similar to coupled patches) is also implemented but commented out. I understand that his correction is necessary for cases like the ERCOFTAC diffuser Case0 with a GGI at cross section B. My question is the following. The GGI patches have to distinguish between master and slave. Wouldn't it be consistent to do this also for the calculation of the correction vectors? if (master()) { const scalarField& patchDeltaCoeffs = deltaCoeffs(); vectorField patchDeltas = delta(); vectorField n = nf(); cv = n - patchDeltas*patchDeltaCoeffs; } else { const scalarField& patchDeltaCoeffs = shadow().deltaCoeffs(); vectorField patchDeltas = shadow().delta(); vectorField n = shadow().nf(); cv = interpolate(-n + patchDeltas*patchDeltaCoeffs); } Or wouldn't that be correct? Regards david |
January 23, 2009, 11:16 |
Interesting, but very very dan
#31 |
Hrvoje Jasak
Rep Power: 33 |
Interesting, but very very dangerous.
1) in GGI i synthensise virtual cell centres right in front of master cell centres using interpolation, With those cell centres, non-orthogonal correction is zero: that is how I made them. Therefore, the correct correction should be zero, right? 2) the second viewpoint is that we can have facets from intersections that pick up its own non-orthogonal correction, which should be fully taken into account. Unfortunately, this means that I do not have enough non-orthogonal correction vectors (I need one for each weight). Thus: I need to to weighted interpolation. However, getting even a small error in non-orthogonal correction, I will get a mass ocnservation error, which is very very dangerous. So, on balance and with reference to point 1, I switched the projection off. Feel free to switch the other one on and test it to death for mass conservation. Hope this helps, Hrv
January 25, 2009, 20:03 |
Hi Hrv
I see the problem. I
#32 |
David Hora
Rep Power: 17 |
Hi Hrv
I see the problem. I will test it and kepp a special eye on the mass conservation. I assume that it's not reasonable to define a knock-out criterion for it. The best way to judge the quality of the results will probably be the comparison of the different procedures. Thanks a lot David |
January 27, 2009, 05:59 |
Hi Martin,
I couldn't get pas
#33 |
Pal Schmitt
Rep Power: 17 |
Hi Martin,
I couldn't get past gmail security so I need to upload the file here... Thanks a lot for Your help, Pal |
January 29, 2009, 13:04 |
did you find out anyth
#34 |
Christina Smuda
Rep Power: 17 |
did you find out anything about the warnings from function GGIInterpolation coming up when using the mixerGgiFvMesh? I'm having the same warnings when running my case. Thanks, Christina |
January 30, 2009, 00:10 |
Hello Christina,
Without an
#35 |
Martin Beaudoin
Rep Power: 22 |
Hello Christina,
Without any information about your case or mesh, I cannot help you much. I am currently working with Pal's case and this turns out to be quite an interesting exercise. In his case, the Warnings are generated by the presence of concave facets in the GGI patches. His mesh was generated using snappyHexMesh, which seems to allow the generation of concave facets. The presence of concave facets in the GGI patches is a problem because the computation of the GGI weighting factors is based on cutting, and the Sutherland-Hodgman algorithm actually doing the intersection requires convex facets only. The Warning simply means that some intersecting facets have been properly identified, but the intersection area between the facets turns out to be zero, which is non-sense. Two solutions for this problem: 1: Somehow modify the snappyHexMesh settings for this mesh generation in order to get convex-only facets. Checkout the description of the parameter maxConcave in your snappyHexMeshDict file, this seems to be possible. I don't know if this is advisable, and I don't know how this mesh would turn out. I have not played much with snappyHexMesh so far. 2: For the current GGI implementation, replace the Sutherland-Hodgman algorithm by some other cutting algorithm that is robust in the presence of concave facets. I already know which algorithm I want to use for this, it is just a matter of coding it. But I need to explore this problem a little bit more before actually considering replacing the Sutherland-Hodgman algorithm for the GGI. I will keep you posted. Martin |
February 3, 2009, 11:53 |
I changed my mesh so it w
#36 |
Pal Schmitt
Rep Power: 17 |
I changed my mesh so it won't have concave faces on the patch, didn't help. Any idea? |
February 9, 2009, 17:59 |
Hi Pal,
same problem here.
#37 |
Hi Pal,
same problem here. I get floating point exceptions on the occasion with GGI and haven't figured out yet what causes them. It also seems that starting from a previously saved timestep will not necessarily reproduce the floating point error, at least not at the same calculation time. cheers, -Louis |
February 9, 2009, 19:19 |
@Pal: as I told you before, yo
#38 |
Martin Beaudoin
Rep Power: 22 |
@Pal: as I told you before, you still have concave faces in your mesh generated with snappyHexMesh, even though checkMesh is not reporting them. Use the latest version of checkMesh from 1.5-dev, and adjust the tolerance factors.
@Louis: not enough information to help you much. Martin |
February 11, 2009, 08:21 |
Hello Martin,
thank you for
#39 |
Christina Smuda
Rep Power: 17 |
Hello Martin,
thank you for your explanation. Since I'm using snappyHexMesh for 3d mesh generation, too, probably concave faces cause the same warning as in Pal's case. If you have any news on this, it would be great if you could let me know. In the meanwhile I started to use the icoDyMFoam solver with mixerGgiFvMesh with a simpler geometry (2d) in order to get a feeling for the solver and to develop my own solver including energy equation with viscous heating, etc. But unfortunately I already failed running the standard icoDyMFoam solver with mixerGgiFvMesh for my case. I already ran the same geometry using sliding interfaces in OpenFoam (mixerFvMesh) and after increasing the number of PISO correctors it converged very well to the expected solution. When I switched to mixerGgiFvMesh the solution wouldn't converge anymore. I always get a floating point error - no matter which solver settings I choose. Since you are one of the experts in GGIs, I would like to ask you, whether you could maybe have a look at my case. I already described the problem in a different thread ( http://www.cfd-online.com/OpenFOAM_Discus/messages/1/10945.html?1233939941). My case is also posted there. It would be great if you could give me a hint on what I could change in order to make the case run better. I'm almost in to giving up on OpenFoam and returning back to Fluent, even though I prefer OpenFoam. Thank you very much, Christina |
February 11, 2009, 12:02 |
Hello Christina,
Sure, I wi
#40 |
Martin Beaudoin
Rep Power: 22 |
Hello Christina,
Sure, I will take a look. Be patient though, I am kind of stuck on other activities for the coming week or so. I have downloaded your rotor2Dggi.rar archive. Is this the latest version available? If not, I would appreciate if you could send me your latest case version as well. Just click on my name to grab my Email address. Martin |
velocity update | fluent_urs | FLUENT | 6 | July 8, 2008 12:41 |
FLEXlm update or ?? | Kasper Skriver | Siemens | 2 | March 1, 2007 11:38 |
IcoTopoFoam update | hjasak | OpenFOAM Running, Solving & CFD | 0 | March 28, 2005 22:32 |
UDF update profile | ramesh | FLUENT | 0 | June 29, 2003 15:14 |
MOUSE - any update? | Pei-Ying Hsieh | Main CFD Forum | 1 | March 19, 2001 06:04 |
