March 14, 2009, 22:45 |
Hello FOAM'ers,
I am new to O
Ashish Nedungadi
Rep Power: 17 |
Hello FOAM'ers,
I am new to OpenFOAM and I apologize if this is a trivial problem. I am not clear on how to go about initializing the flowfield. I am used to running various commercial flow solvers where you can specify initial conditions in many different ways and the code takes care of it. So, if you have a 3D structured (i.e. hex) or unstructured (i.e. tets/prisms) mesh, how do you all go about initializing the flowfield? If I want to specify different initial conditions in different places (e.g. shocktube) how do I do that? I searched through the posts, but could not find anything that addresses my problem. Thanks! Ashish |
March 15, 2009, 04:52 |
Look at the damBreak tutorial
Hrvoje Jasak
Rep Power: 33 |
Look at the damBreak tutorial for application interFoam: you need a utility called setFields.
Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
Flowfield initialization in OpenFOAM | ashishnedungadi | OpenFOAM Running, Solving & CFD | 0 | March 14, 2009 22:43 |
Conversion variable profiles to OpenFoam initialization BC profiles and mapFields | vvqf | OpenFOAM Pre-Processing | 1 | February 14, 2006 10:08 |
How to get data I need from a converged flowfield? | Ko | Siemens | 1 | September 20, 2003 10:22 |
Froozen flowfield | Allan | Siemens | 3 | November 16, 2001 14:30 |
pressure in turbulence flowfield | Yu-Li Chang | Main CFD Forum | 0 | April 28, 2000 11:14 |
