icoReactingMultiphaseInterFoam to simulate condensation of steam in a 2D Domain
Old   Yesterday, 09:00
Question icoReactingMultiphaseInterFoam to simulate condensation of steam in a 2D Domain
Akshay Mani
akshaymani94 is on a distinguished road
Hi Everybody,
I am fairly new to OpenFOAM. I am currently facing a challenge in simulating steam condensation inside a 2D domain. In this problem, the steam enters the domain through the inlet and comes in contact with the walls at a lower temperature, leading to the condensation of steam to water and then leaving through the outlet.
I used interCondensatingEvaporatingFoam initially but as I wanted to use externalWallHeatFluxTemperature boundary condition for the walls I had to switch to icoReactingMultiphaseInterFoam.
The simulation is running fine but I don't get any condensation in my domain. I am sharing all the necessary files below, please tell me where I am going wrong.
air,gas file
PHP Code:
/*--------------------------------*- C++ -*----------------------------------*\
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  v2306                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
|    \\/     M anipulation  |                                                 |
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      air.gas;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
wall.3
type            zeroGradient;
Inlet
type            fixedValue;
//inletValue      $internalField;
       //value           $internalField;
       //inletValue        uniform 1;
value            uniform 0.2;
outlet
type            inletOutlet;
inletValue      uniform 0.2;
value           uniform 0.2;
frontAndBackPlanes
type            empty;
vapour.gas file
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      vapour.gas;
internalField   uniform 1;
boundaryField
wall.3
type            zeroGradient;
// type        fixedGradient;
      // gradient        uniform -0.01;
Inlet
type            fixedValue;
value            uniform 0.8;
outlet
type            inletOutlet;
inletValue        uniform 0.8;
value            uniform 0.8;
frontAndBackPlanes
type            empty;
alpha.gas file
PHP Code:
|  \\    /   O peration     | Version:  2306                                  |
FoamFile
version     2.0;
format      ascii;
arch        "LSB;label=32;scalar=64";
    class
volScalarField;
location    "0";
object      alpha.gas;
boundaryField
outlet
type            inletOutlet;
value           uniform 1;
Inlet
type            fixedValue;
value           uniform 1;
wall.3
type            zeroGradient;
frontAndBackPlanes
type            empty;
alpha.liquid file
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
location    "0";
object      alpha.liquid;
boundaryField
outlet
type            inletOutlet;
Inlet
type            inletOutlet;
wall.3
type            zeroGradient;
//type            fixedValue;
        //value           uniform 1;
frontAndBackPlanes
type            empty;
U file
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volVectorField;
object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
wall.3
type        fixedValue;
value       uniform (0 0 0);
Inlet
      //  type                flowRateInletVelocity;
      //  massFlowRate        0.2511;
      //  extrapolateProfile  yes;
      //  rho                 rho;
      //  rhoInlet            0.9;
      //  value               uniform (1 0 0);
type            fixedValue;
value           uniform (-0.005 0);
outlet
type            zeroGradient;
frontAndBackPlanes
type            empty;
p_rgh file
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      p_rgh;
dimensions          --2 0 0 0 0 ];
internalField       uniform 1e5;
boundaryField
wall.3
type            zeroGradient;
Inlet
      //  type            prghTotalPressure;
        //p0              uniform 1e5; // Total pressure
       // rho             rho;            // Density field
       // psi             none;           // Optional for compressibility
       // gamma           1;              // Optional (compressible flows)
type            fixedValue;
value           uniform 1e5;
outlet
type            fixedValue;
value           uniform 1e5;
//outlet
        //type         fixedValue;
        //value        uniform 160000;
frontAndBackPlanes
type            empty;
T file
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      T;
dimensions          [0 0 0 1 0 0 0];
internalField       uniform 373;
boundaryField
wall.3
type            externalWallHeatFluxTemperature;
mode            coefficient;
Ta              constant 278.0;
h               constant 10.0;
thicknessLayers (3.76);
kappaLayers     (16.2);
kappaMethod     fluidThermo;
      //  type            fixedValue;
      //  value           uniform 278;
Inlet
type            fixedValue;
value           uniform 373;
outlet
type            zeroGradient;
frontAndBackPlanes
type            empty;
phaseProperties file
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
object      phaseProperties;
type    massTransferMultiphaseSystem;
phases  (gas liquid);
liquid
type            pureMovingPhaseModel;
gas
type            multiComponentMovingPhaseModel;
surfaceTension
gas and liquid)
type            constant;
sigma           0.0589;
massTransferModel
liquid to gas)
type                kineticGasEvaporation;
species             vapour.gas;
C                   -0.1;    //C is the model constant. If C  > 0 the model acts as evaporation, if C <  0 is condensing.
isoAlpha            0.2;
Tactivate           373;
thermophysicalProperties.gas
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
object      thermophysicalProperties.gas;
thermoType
type            heRhoThermo;
mixture         multiComponentMixture;
transport       const;
thermo          hConst;
equationOfState incompressiblePerfectGas;
specie          specie;
energy          sensibleEnthalpy;
species
air
    vapour
inertSpecie air;
vapour
specie
nMoles      1;
molWeight   18.9;
equationOfState
pRef         1e5;
thermodynamics
Hf          0;
Cp          2030;
transport
mu          0.9e-05;
Pr          0.7;
air
specie
nMoles      1;
molWeight   28.9;
equationOfState
pRef         1e5;
thermodynamics
Hf          0;
Cp          900;
transport
mu          0.9e-05;
Pr          0.7;
thermophysicalProperties.liquid
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
object      thermophysicalProperties.liquid;
thermoType
type            heRhoThermo;
mixture         pureMixture;
transport       const;
thermo          hConst;
equationOfState rhoConst;
specie          specie;
mixture
specie
nMoles          1;
molWeight       18.9;
equationOfState
rho             958.4;
thermodynamics
Cp              4216;
// Hf              -2.45e6;
Hf              2.45e6;
transport
Pr              6.62;
mu              959e-6;
The residuals after 10seconds is shown below:
PHP Code:
Courant Number mean0.314005 max1.3449
Interface Courant Number mean0 max0
Maximum ddtAlpha
0
Maximum DiffNum
0
deltaT
0.01
Time
9.99
DILUPBiCGStab
:  Solving for alpha.gasInitial residual 0.124396, Final residual 7.45994e-10No Iterations 3
MULES
DILUPBiCGStab
:  Solving for alpha.liquidInitial residual 0, Final residual 0No Iterations 0
MULES
Phase
-sum volume fractionminmax 1 1 1
alpha
.gas volume fraction 1  Min(alpha) = 1  Max(alpha) = 1
alpha
.liquid volume fraction 0  Min(alpha) = 0  Max(alpha) = 0
PIMPLE
iteration 1
DILUPBiCGStab
:  Solving for Xvapour.gasInitial residual 0.000276349, Final residual 2.90958e-09No Iterations 1
MULES
air
.gas mass fraction =   Min(Y) = 6.10116e-12  Max(Y) = 0.2
vapour
.gas mass fraction =   Min(Y) = 0.8  Max(Y) = 1
DILUPBiCGStab
:  Solving for TInitial residual 3.56367e-06, Final residual 3.05754e-08No Iterations 4
min
/max(T) = 291.949373
DICPCG
:  Solving for p_rghInitial residual 0.00193553, Final residual 3.01285e-05No Iterations 4
time step continuity errors
sum local 2.48054e-07, global = -5.05432e-08cumulative = -1.01757e-05
DICPCG
:  Solving for p_rghInitial residual 0.000383792, Final residual 8.50993e-10No Iterations 59
sum local 3.31346e-08, global = 1.01364e-10cumulative = -1.01756e-05
ExecutionTime
13.39 s  ClockTime 14 s
Courant Number mean
0.314028 max1.3449
Maximum ddtAlpha
0
Maximum DiffNum
0
deltaT
0.01
Time
10
DILUPBiCGStab
:  Solving for alpha.gasInitial residual 0.119132, Final residual 3.2368e-10No Iterations 3
MULES
DILUPBiCGStab
MULES
Phase
alpha
alpha
PIMPLE
iteration 1
DILUPBiCGStab
:  Solving for Xvapour.gasInitial residual 0.000277555, Final residual 2.80145e-09No Iterations 1
MULES
air
.gas mass fraction =   Min(Y) = 6.22458e-12  Max(Y) = 0.2
vapour
DILUPBiCGStab
:  Solving for TInitial residual 3.43375e-06, Final residual 3.42081e-08No Iterations 4
min
DICPCG
:  Solving for p_rghInitial residual 0.00184065, Final residual 3.45061e-05No Iterations 2
sum local 2.82363e-07, global = 7.56102e-08cumulative = -1.01e-05
DICPCG
:  Solving for p_rghInitial residual 0.000266362, Final residual 6.71181e-10No Iterations 57
sum local 3.14438e-08, global = -1.02927e-10cumulative = -1.01001e-05
ExecutionTime
13.41 s  ClockTime 14 s
End
Thanks in Advance.
akshaymani94 is offline   Reply With Quote
condensation flow, openfoam
Consultation for CFX/FLUENT simulation of steam condensation inside a pipe selvam2487 CFX 2 December 6, 2018 17:43
bad results of steam jet condensation into subcooled water Yamaha CFX 2 June 8, 2018 01:40
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 23:43
