codedMixed runs well on serial but crashes in parallel
Old   December 23, 2024, 15:12
Default codedMixed runs well on serial but crashes in parallel
Matias Alberto Aguirre
maguirre is on a distinguished road
Hi foamers!
During a parallel simulation, I encounter an issue with a custom boundary condition in OpenFOAM. The boundary condition is applied to a patch (plasmaSurf) and works fine in serial runs. However, in parallel, the simulation crashes with errors related to field sizes and bad memory allocation.
Key Details:
  • The plasmaSurf patch has zero faces on some processors after decomposition.
  • Errors include messages like:
    • size 0 is not equal to the given value of X (on processors with nFaces = 0)
    • bad size -Y (on processors with nFaces != 0)
What I've Tried:
  • Verified the mesh with checkMesh -parallel (result is OK).
  • Checked plasmaSurf in the processorX directories—confirmed it has zero faces on some processors.
  • Simplified the boundary condition logic only to set value or gradient, but the issue persists in parallel runs.
  • Switched to a simpler boundary condition (e.g., fixedValue) as a temporary fix, which works fine in parallel.
  • Ensured decomposePar produces an evenly balanced decomposition and checked for mesh consistency.
Suspected Cause: The problem seems related to how the codedMixed boundary condition handles patches with zero faces in parallel. This might be a bug in my implementation or an inconsistency in how OpenFOAM distributes the patch data.
Question: How can I ensure the codedMixed boundary condition is robust to parallel runs where a patch might have zero faces on some processors? Are there best practices for handling such scenarios, or modifications needed to the codedMixed code to avoid these issues?
Code Implemented:
plasmaSurf
  type            codedMixed;
  namedummy_code;
  refValue        uniform 300;
  refGradient     uniform 0;
  valueFraction   uniform 0;
  code
    if (this->patch().size() == 0) // No faces on this processor
      return;
    scalarField& refGrad = this->refGrad();
    scalarField& refVal = this->refValue();
    scalarField& valueFraction = this->valueFraction();
    // Initialize to zero or default values
    refGrad = scalarField(patch().size(), 0.0);
    refVal = scalarField(patch().size(), 300.0);
    valueFraction = scalarField(patch().size(), 0.0);
(that code does not work even if the code block is empty)
Typical Error:
[1]
[1]
[1] --> FOAM FATAL IO ERROR:
[1] size 0 is not equal to the given value of -1871300200
[1]
[1] file: IStringStream.sourceFile from line 0 to line 4.
[1]
[1]     From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = double; Foam::label = int]
[1]     in file /home/ubuntu/OpenFOAM/OpenFOAM-11/src/OpenFOAM/lnInclude/Field.C at line 208.
[1]
FOAM parallel run exiting
[1]
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] bad size -534376040
[0]
[0]     From function void Foam::List<T>::setSize(Foam::label) [with T = double; Foam::label = int]
[0]     in file /home/ubuntu/OpenFOAM/OpenFOAM-11/src/OpenFOAM/lnInclude/List.C at line 285.
[0]
FOAM parallel run aborting
[0]
MPI_ABORT was invoked on rank 1 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[0] #0  Foam::error::printStack(Foam::Ostream&)
Any insights or suggestions would be greatly appreciated!
maguirre is offline   Reply With Quote
codedmixed, foamrun, parallel
type limitTemperature problem AdamRM OpenFOAM Running, Solving & CFD 6 November 16, 2023 06:55
chtMultiRegionFoam is slower in parallel than serial froberto OpenFOAM Running, Solving & CFD 2 September 12, 2023 14:55
To continue from latestTime of a previous serial run in parallel redbullah OpenFOAM 2 July 26, 2018 15:01
Different results between parallel and serial processing Sarah_Fluent FLUENT 5 March 6, 2018 12:42
Moving mesh crashes in parallel (1.5-dev) jploz OpenFOAM Programming & Development 8 October 21, 2009 18:22
