Error while compiling a sinusoidal pressure wave inlet condition. |
December 12, 2024, 12:03 |
Rajendra Kumar
Rep Power: 10 |
I am getting the following error when I try to run a solver (dbnsFoam), where I have modified the inlet pressure condition to be a sinusoidal function using codeFixedValue. Can someone tell me what this error is about and how to resolve it. I used make libso compilation for dynamic code folder also.
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112 Arch : "LSB;label=32;scalar=64" Exec : dbnsFoam Date : Dec 12 2024 Time : 16:58:33 Host : IMTsimul-jb3 PID : 1768 I/O : uncollated Case : /home/rajendra/tut/forwardStep nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Transient analysis detected pseudoTime: max iterations = 50, tolerance = 1e-05, relTol = 0.001 Local timestepping selected Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Using dynamicCode for patch inlet on field p at line 18 in "/home/rajendra/tut/forwardStep/0/p.boundaryField.inlet" Could not load "/home/rajendra/tut/forwardStep/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libinlet_d1bd48bc3d61125a92466b70ac0a55c3bbefc552. so" /home/rajendra/tut/forwardStep/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libinlet_d1bd48bc3d61125a92466b70ac0a55c3bbefc552. so: cannot open shared object file: No such file or directory Invoking wmake libso /home/rajendra/tut/forwardStep/dynamicCode/inlet wmake libso /home/rajendra/tut/forwardStep/dynamicCode/inlet Ctoo: fixedValueFvPatchFieldTemplate.C /home/rajendra/tut/forwardStep/0/p.boundaryField.inlet: In member function ‘virtual void Foam::inletFixedValueFvPatchScalarField::updateCoe ffs()’: /home/rajendra/tut/forwardStep/0/p.boundaryField.inlet:32:66: error: invalid user-defined conversion from ‘Foam::tmp<Foam::Field<double> >’ to ‘Foam::Field<double>&’ [-fpermissive] In file included from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/refPtr.H:46:0, from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/PtrListI.H:30, from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/PtrList.H:231, from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/List.C:32, from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/List.H:403, from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/wordList.H:50, from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/patchIdentifier.H:42, from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/polyPatch.H:45, from /usr/lib/openfoam/openfoam2112/src/finiteVolume/lnInclude/fvPatch.H:42, from /usr/lib/openfoam/openfoam2112/src/finiteVolume/lnInclude/fvPatchField.H:50, from /usr/lib/openfoam/openfoam2112/src/finiteVolume/lnInclude/fixedValueFvPatchField.H:59, from /usr/lib/openfoam/openfoam2112/src/finiteVolume/lnInclude/fixedValueFvPatchFields.H:31, from fixedValueFvPatchFieldTemplate.H:40, from fixedValueFvPatchFieldTemplate.C:29: /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/tmp.H:270:9: note: candidate is: Foam::tmp<T>:perator const T&() const [with T = Foam::Field<double>] <near match> operator const T&() const { return cref(); } ^~~~~~~~ /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/tmp.H:270:9: note: no known conversion from ‘const Foam::Field<double>&’ to ‘Foam::Field<double>&’ /home/rajendra/tut/forwardStep/0/p.boundaryField.inlet:32:67: error: conversion from ‘const Foam::Field<double>’ to ‘Foam::Field<double>&’ discards qualifiers [-fpermissive] /home/rajendra/tut/forwardStep/0/p.boundaryField.inlet:41:31: error: lvalue required as left operand of assignment /usr/lib/openfoam/openfoam2112/wmake/rules/General/transform:34: recipe for target 'Make/linux64GccDPInt32Opt/fixedValueFvPatchFieldTemplate.o' failed make: *** [Make/linux64GccDPInt32Opt/fixedValueFvPatchFieldTemplate.o] Error 1 --> FOAM FATAL IO ERROR: (openfoam-2112 patch=220610) Failed wmake "dynamicCode/inlet/platforms/linux64GccDPInt32Opt/lib/libinlet_d1bd48bc3d61125a92466b70ac0a55c3bbefc552. so" file: 0/p.boundaryField.inlet at line 18 to 21. From void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const in file db/dynamicLibrary/codedBase/codedBase.C at line 240. FOAM exiting
Regards, Rajendra |
Total pressure Inlet vs opening pres. and Dirn | jins9158 | CFX | 0 | March 7, 2022 20:23 |
Pressure Inlet Boundary Condition for gas-solid fluidized bed | m.uzair | Fluent Multiphase | 0 | January 18, 2018 07:08 |
Time dependant pressure boundary condition | yosuke1984 | OpenFOAM Verification & Validation | 3 | May 6, 2015 07:16 |
Pressure Inlet Boundary Condition | Prasad | FLUENT | 6 | April 9, 2013 22:32 |
How to set up the inlet boundary condition for a low pressure case? | beastieboys6 | FLUENT | 3 | April 10, 2012 23:46 |
