December 5, 2024, 09:56 |
READ Flag for LRR turbulence model
Dear community,
I tried to make a simulation with the LRR turbulence model. Therefore I followed the instructions as described in this tread: simpleFoam tutorial PitzDaily using Reynolds stress tensor (LRR RASModel) As I am using the Foundation version I managed to get the R file via the command: Code:
foamPostProcess -solver incompressibleFluid -func 'turbulenceFields(R)' -latestTime Code:
You are probably trying to solve for a field with a default boundary condition. However, I found some hints how to resolve this error in those links: OpenFoam - a little user manual, Gerhard Holzinger, Page 385: https://www.researchgate.net/publica...le_user_manual Or: Solving an additional equation I believe that those two documents are adressing what's wrong in my case. But unfortunately I am not aware enough to find the file which I have to change. Can one please give me the path to the file wich need to be changed? Any other hint with respect to the LRR model is welcome! Best regards Michael. |
lrr, rsm |
Anomaly in Mach Flow Behavior with SST Turbulence Model | Kuan | SU2 | 0 | March 26, 2024 03:22 |
Spalarat - Allmaras turbulence model | saisanthoshm88 | Main CFD Forum | 1 | June 16, 2014 17:33 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Read IOdictionary entries from within turbulence model | Arnoldinho | OpenFOAM Programming & Development | 9 | August 11, 2012 08:15 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 10:52 |
