Issues with mhdFoam
Old   December 3, 2024, 07:16
Default Issues with mhdFoam
Jagan Mohan
jagan1mohan is on a distinguished road
mhdFoam works well "only" for tutorial case, is this the situation with you as well? In this tutorial setup, all transport properties are equal to 1.0, that is, all of them.
I'm using OF12 and any change in transport properties, solver iterates for long time and finally shows "imposed inlet velocity" values across the entire domain. Please see images of U and p-fields after 10 secs with inlet velocity set at fixedValue 0.00005 m/s.
This behavior is not effected by mesh, time-step refinements, reducing solver tolerances.
Solver fails to capture fully-developed-parabolic-profile even for small inlet velocities and very very weak, almost zero magnetic field.
Can someone suggest what could be issue?
Best,
jagan1mohan is offline   Reply With Quote
convergence, mhdfoam
Pressure solving on mhdFoam itaniOmar OpenFOAM Running, Solving & CFD 0 September 9, 2024 10:45
MHD solvers ? mhdFoam, axisymmetric case RomainBou OpenFOAM Running, Solving & CFD 2 May 30, 2024 07:50
Convergence issues for Flat plate with sharp edge rajnarayang FLUENT 3 June 20, 2017 13:02
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 17:18
[General] Some Paraview Issues I can not solve MR_Chicho ParaView 1 September 24, 2012 06:03
