Yesterday, 15:14 |
Water not visible in interFOAM, periodic BC
Anurag
Rep Power: 3 |
Hi
I am trying to simulate air-water flow in a rect pipe using periodic BC at inlet and outlet. After giving a force in fvOptions to keep the water running i am running interFoam, but after the run I cannot see water coming in from the inlet surface, although the vel, p fields are changing with time. But it runs successfully when i use a fixed value instead of periodic BC. I have assigned cyclic in 0 folder and boundary files. ANy help is appreciated! thanks Am I doing any wrong in setting up the fvOptions force field? I use the following code for the force field momentumSource { type meanVelocityForce selectionMode all; fields (U); Ubar (1 0 0); } Thanks if someone can provide any assistance!! |
Periodic BC in interFOAM | anubasu | OpenFOAM Running, Solving & CFD | 0 | August 16, 2024 22:35 |
interFoam: defining boundary conditions (at inlet and outlet) based on water heights | atul1018 | OpenFOAM Running, Solving & CFD | 0 | January 2, 2024 10:31 |
interFoam current, Why Water Level decreases in time | Jekke123456789 | Main CFD Forum | 1 | April 12, 2020 04:53 |
Water level decreasing - interFoam | OEC | OpenFOAM Running, Solving & CFD | 0 | April 16, 2015 10:28 |
(interfoam) shear stress at water air interface ! | openfoam1 | OpenFOAM | 11 | October 27, 2014 04:59 |
