OpenFOAM and weather nowcasting
Old   December 1, 2024, 12:08
Default OpenFOAM and weather nowcasting
Raj Solanki
Raj Solanki is on a distinguished road
I am trying to make a project, in which my initial idea was to create a weather forecasting project involving both machine learning and cfd. So the plan was that by running simulations regarding weather nowcasting in OpenFOAM, I can train the Machine learning model and then input the real life data and compare with what happened exactly and check the accuracy.
But I have no idea whether I can use OpenFOAM in that way or not, and whether it's feasible or not. The machine learning part is anyways going to happen, but I am not sure about OpenFOAM at all. If someone can please direct me some knowledge or atleast a confirmation that OpenFOAM can be used for such techniques then it'll be great.
Raj Solanki is offline   Reply With Quote
Old   December 2, 2024, 07:04
Tobermory will become famous soon enough
Yes, it can in principle.
However, the best way of viewing OpenFOAM is as a toolbox. It contains all the tools you need to model most fluid flows, including the atmosphere (although some thought will be needed for humidity, which is key in weather forecasting).
However, a toolbox won't build a car for you or tell you how to build a car. You have to have that knowledge yourself.
Same with OpenFOAM. In other words, if you don't know anything about weather forecasting, then OpenFOAM is useless for you.
Tobermory is offline   Reply With Quote
openfoam is installed on linux, but windows is damaged! minaret Lounge 5 April 7, 2015 22:58
Heat Transfer in OpenFoam sandeeprapol OpenFOAM Running, Solving & CFD 0 February 7, 2015 04:32
forced convection heat transfer in openfoam sandeeprapol OpenFOAM Running, Solving & CFD 0 February 1, 2015 07:05
OpenFOAM on Condor Clusters? philippose OpenFOAM Installation 0 July 17, 2009 03:39
Examples of the ODE capabilities in OpenFOAM philippose OpenFOAM Running, Solving & CFD 3 February 19, 2008 17:59
