dynamicMotionSolverFvMeshAMI with kinematicCloud
Old   November 29, 2024, 17:19
Default dynamicMotionSolverFvMeshAMI with kinematicCloud
William Peace
WJPeace1 is on a distinguished road
Hi all,
I'm running a stirred tank simulation with an AMI rotating region. I have tried this with v2312 and v2406. I have received the following error when using dynamicMotionSolverFvMeshAMI with a kinematicCloud specified:
[3] --> FOAM FATAL ERROR: (openfoam-2406)
[3] Global positions are not available. Cloud::storeGlobalPositions has not been called.
[3]
[3]     From void Foam::Cloud<ParticleType>::autoMap(const Foam::mapPolyMesh&) [with ParticleType = Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> >]
[3]     in file /rds/bear-apps/2023a/EL8-ice/software/OpenFOAM/v2406-foss-2023a/OpenFOAM-v2406/src/lagrangian/basic/lnInclude/Cloud.C at line 308.
[3]
FOAM parallel run exiting
I have got a simulation running with the dynamicMotionSolverFvMeshAMI without particles, and I do have a case with the original dynamicMotionSolverFvMesh option, but the AMI interface is not perfect (I have been struggling a lot with the weights at the interface, hence why I am trying this).
Any help or suggestions as to what is causing this, and whether there is a quick and/or easy way of solving this!
Many thanks
Will
Last edited by WJPeace1; November 29, 2024 at 17:46. Reason: including version numbers
WJPeace1 is offline   Reply With Quote
dynamicmesh, kinematiccloud, particles, stirred tank
kinematic cloud properties-Regd thegauravonline OpenFOAM Programming & Development 11 August 8, 2023 06:52
Trying to get kinematicCloud properties in twoPhaseSystem.C chenbo OpenFOAM Programming & Development 3 April 28, 2022 12:54
particleCount 0/no particles injected: icoUncoupledKinematicParcelFoam particlecount_0 OpenFOAM Running, Solving & CFD 1 March 6, 2021 15:09
error in kinematicCloud kalyan OpenFOAM Running, Solving & CFD 8 December 29, 2019 00:52
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
