Calculating Pressure Drop in Pipe at High Velocities
Old   November 23, 2024, 23:07
Default Calculating Pressure Drop in Pipe at High Velocities
Remusco is on a distinguished road
I am working in OpenFoam trying to compute the pressure drop in a piping system. The fluid is air, flowing at ~mach 0.5. I did write my own Python code to analytically solve this, but I want to validate it using CFD. When I try to solve this problem for a short length of pipe (~5 feet), the solver runs all night, and the residuals do not drop at all. What am I missing here? When I open the results in Paraview all I get is the same values for the pressure everywhere.
Physics model:
Steady-state
single phase
non-isothermal
viscous
RANS k-epsilon
Fluid: air
Pipe size: 76mm
Inlet volume flow rate: 1.055 m^3/sec
Inlet turbulence intensity: 2.92%
inlet length scale: 7mm
Outlet boundary: 100,000 Pa
Mesh:
Snappyhex mesh 8mm base size,
prism layers near boundary, 15mm total thickness, 15 cells, 1.1 expansion factor
I am a noob at cfd. I am probably missing something simple here.
Remusco is offline   Reply With Quote
compressible, openfoam
Simulating Heat xfer and pressure drop across a pipe NickNosalik FLUENT 10 September 5, 2019 09:47
Need Help! High pressure Gas discharge from tank to tank through a pipe superarthur86 FLUENT 2 June 16, 2017 11:22
divergence due to high pressure drop in two-stroke scavenging renna.ale FLUENT 4 May 17, 2013 16:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
