NASA NACA 0012 Validation Case using SSG-LRR-Omega model in OpenFOAM
Old   November 15, 2024, 14:02
Default NASA NACA 0012 Validation Case using SSG-LRR-Omega model in OpenFOAM
zhukovsky
zhukovsky is on a distinguished road
Hello everyone,
I am trying to obtain a solution using the SSG-LRR-Omega Reynolds Stress Model in OpenFOAM v2312. I have implemented the model which is on the GitHub repository: (https://github.com/nainapisharoti/SSG-LRR-omega-gamma.) First, I tried this model for the pitzDaily tutorial and obtained convergence and reasonable results. Then, I tried the NACA 0012 validation case of NASA with the provided 897x257 grid. With the k-w SST model, I also obtained convergence and reasonable results but the solution diverged with the SSG-LRR-Omega Reynolds Stress model. NASA obtained solutions for this model using CFL3D, TAU, and FUN3D solvers.
I started the RSM simulation after 7000 iterations with SST and residuals can be seen in the image. After 1000 iterations with RSM, the residuals were progressing not that badly but after 1000 iterations omega residual started to oscillate and the solution diverged afterward.
I can add the case setup if you want.
zhukovsky is offline   Reply With Quote
reynolds stress model, rsm, ssg-lrr-omega
problem in validation on naca 0012 mahdi_sangbori FLUENT 9 August 27, 2015 17:40
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
