Strange temperature behaviour with solidificationMeltingSource
Old   November 13, 2024, 10:34
Unhappy Strange temperature behaviour with solidificationMeltingSource
nando83 is on a distinguished road
Hi foamers,
I am experiencing a problem in using solidificationMeltingSource.
I am trying to simulate the solidification of a liquid steel slice (2D simulation) setting a melting temperature of 1783.15 K, as you can see in fvOptions file, and initializing a temperature of 1824 K for the whole domain (see 0/T file).
In the file attached you can see the temperature trends for some probes: it seems that the initial temperature is just above the melting temperature instead the one I indicated (1824 K --> 1550 °C).
How is it possible?
What is wrong with my case?
Please find attached also the case:
- Extract the files
- Run BlockMest
- Move the polyMesh folder from ./constant/ to ./constant/billet/
- Run chtMultiRegionFoam
- Open with paraview
Any help would be much appreciated.
Thank you,
Ferdinando
nando83 is offline   Reply With Quote
Old   November 14, 2024, 06:15
Alczem is on a distinguished road
Hey!
My guess is that the temperature immediately drops down to the melting temperature (1510°C) even though you initialized it at 1550°C.
It probably happens because physically, the temperature of your system cannot go over the melting temperature (except if you provide a heating source and that all of your steel eventually melts, then the liquid steel will heat up over 1510°C).
Alczem is offline   Reply With Quote
Old   November 18, 2024, 07:06
Smile Interesting sim
sridhar
sridharmani is on a distinguished road
Your simulation seems to be interesting can you elaborate on the solver you are using and whether you made any changes to the solver.
sridharmani is offline   Reply With Quote
Old   November 18, 2024, 08:37
I discovered that adding alpha1 and alpha1_0 files in the 0 folder solves the temperature drop. Probably, the default value for these variable is 0 and it means "liquid state" (I suppose) while setting them to 1 in internalField ("solid state") everything works.
Now It is not clear to me why, when solidification happens, the temperature follows a stepwise trend (see the attached picture).
Any hints? Is it normal?
@sridharmani: I made no modification to the solver
Old   November 18, 2024, 09:35
Smile
sridhar
Hey,
I have not personally used this solver but that is for conjugate heat transfer in a phase. While solidification involves two phase where there is a phase transition. So maybe look into more appropriate solver if you are trying to achieve solidification.
solidification & melting, temperature drop
Weird (unphysical) temperature rise with chtMultiRegionFoam Phil910 OpenFOAM Running, Solving & CFD 3 November 9, 2022 10:25
strange extreme low radiation heat flux on fixed Temperature surface fxzf OpenFOAM Running, Solving & CFD 0 March 7, 2018 17:09
Strange behaviour when using compressibleInterFoam with constantAlphaContactAngle TobM OpenFOAM Running, Solving & CFD 2 May 11, 2016 07:34
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
[sprayFoam] strange spray formation behaviour pbalz OpenFOAM Running, Solving & CFD 0 March 23, 2015 12:41
