how to solve for a vovector field that appears in an equation with an inner product? |
November 13, 2024, 07:55 |
Mahdi
Hi all,
Can anyone suggest how to solve for a volvectorfield \OMEGA which appears as a dot product in an equation such as the one below: Dei/Dt=\OMEGA.ei lets says we have ei as a volvectorfield input, and we want to calculate \OMEGA. note fvm:: does not support inner dot product. To give some context: I am trying to obtain a non-objective \omega=curl of velocity (for those of you who are familiar with fluid mechanics you might know Omega is non-objective so one should replace this with objective version \bar{\omega} which ca be calculated as : \bar{\omega}=\omega- \OMEGA where \OMEGA satisfies: De_i/Dt=\OMEGA.ei with ei being eigenvectores of deformation rate. Does anyone know a solver of a library which has doen this? I am sure someone has doen this before so maybe best would be to see what they did instead of calculating eigenvector etc etc Thanks for any help Mahdi |
Solve continuity equation for one dimensional mesh motion velocity. Need derivative i | danylo | OpenFOAM Running, Solving & CFD | 2 | February 22, 2024 06:01 |
solve the equation looks like heat conduction equation | ythw | OpenFOAM Running, Solving & CFD | 1 | October 27, 2023 12:18 |
How to solve pressure correction equation? | Crescendo | Main CFD Forum | 1 | August 11, 2021 11:48 |
Solve a non-differential equation | agustinvo | OpenFOAM Programming & Development | 3 | January 18, 2016 10:22 |
How to solve this kind of continuity equation? | shddx1 | OpenFOAM Programming & Development | 0 | July 7, 2011 16:31 |
