November 8, 2024, 11:26 |
OpenFOAM's y+ <=5 Boundary Conditions
Christoforos Lefkiou
Rep Power: 2 |
Hello everybody,
I am working in a relatively simple task (calculation of drag coefficient of 2D cylinder) and I am using a mesh that has a y+ < 5. Therefore, I won’t use Wall Functions (at least log-law wall functions). I have been searching through the forum (and outside of it) to find what are the B.C for this case, for low values of y+, but I couldn’t find a clear answer. I am working with k-omega SST turbulence model. Can someone please explain what B.C I must use for my cylinder wall in k, omega and nut? Thank you, |
November 12, 2024, 08:40 |
talop
Rep Power: 3 |
Hi clef1,
The "lowReWallFunction" did the trick for me. https://www.openfoam.com/documentati...lFunction.html Similar BCs exist for others as well. Try the banana trick to see the list of available BCs and run a google search for interesting ones. You can also try 3D unsteady RANS and DES. They tend to give better results for this problem. Best |
November 12, 2024, 11:19 |
#3 | |
Rep Power: 2 |
Thank you for your reply, It seems that some k and nut (and omega) wall functions are adjusted depending on y+, therefore we can use them throught the range of y+. I will check your comments, Thanks |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
