November 7, 2024, 05:20 |
BC for p_rgh In closed multiphase flow
Elias Michelsen Tangen
Rep Power: 2 |
Hello!
I am running a 2D multiphase simulation with one water inlet and one air inlet, and one outlet. The pressure increase from inlet to outlet, which does not make sense. I think its related to the BC for p_rgh where I am using zeroGradient at the two inlets, and fixedValue unifrom 0 at the outlet. The pressure goes from -2700 to 0. I am using interFoam. What should be the BC for p_rgh in closed multiphase simulations? Thanks! |
November 7, 2024, 07:54 |
Rep Power: 2 |
I think i found the solution. It was not related to the BC for inlet and outlet, but for the walls. When i applied fixedFluxPressure value uniform 0 at the wall for p_rgh, i got reasonable results.
bc for p_rgh |
Closed loop flow simulation | wudong | OpenFOAM | 0 | June 6, 2024 10:26 |
multiphase flow ,mass and volume fraction imbalance | sope111 | CFX | 16 | September 3, 2018 01:10 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 06:36 |
multiphase flow | leon_jar | CFX | 8 | November 4, 2015 03:06 |
Multiphase flow in atomiser | santhosh1987 | FLUENT | 0 | May 12, 2011 05:26 |
