Issues running LES simulation on custom geometry in OpenFOAM v12 |
November 2, 2024, 11:14 |
Carlos
Hello everyone,
I have successfully run the motorBike LES tutorial using the provided files on OpenFOAM v12. Recently, I attempted to use a new geometry for the same simulation but encountered issues preventing the completion of the run. This new geometry has been validated by running it successfully on the motorBikeSteady tutorial. Here’s a summary of what I’ve done and the problem details: Software and version: OpenFOAM v12 and OpenFOAM v8 using blueCFD. Computer: Windows 11, Core i7-11800H (8 cores), 16 GB RAM, NVIDIA GeForce RTX 3050 Simulation type: LES (Large Eddy Simulation) Tutorial followed: motorBike with LES Issue encountered: The simulation fails to produce results with the new geometry. I tried several approaches: Sometimes, while running the steady part, I can see my geometry but no solution folder is created. Other runs produce result folders, but not my geometry. I run the cases using modified allrun files and also by manually giving the commands. The modification involves calling the geometry and copying it into the constant folder. I am also running the case based on this tutorial: https://www.xsim.info/articles/OpenF...motorBike.html The same geometry works perfectly with the motorBikeSteady tutorial, indicating that the geometry itself isn't the problem. Steps taken to resolve: Verified the setup using the provided tutorial files. Cross-checked the geometry in the motorBikeSteady tutorial, confirming it works. Searched for similar issues on the forum but found no solutions addressing this specific issue. I would greatly appreciate any insights or suggestions from the community on how to resolve this issue. Thanks in advance for your help! Note: Here is a link with the files: https://drive.google.com/drive/folde..._p?usp=sharing Best regards, CarlosMH |
help needed, les, openfoam case |
OpenFOAM v12 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 0 | July 9, 2024 07:05 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 09:17 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 10:38 |
LES simulation of vibrating Wing | gtg627e | OpenFOAM Running, Solving & CFD | 0 | September 6, 2007 02:36 |
