Non-convergence of SA-model for similar y+ values
Old   November 1, 2024, 11:24
Default Non-convergence of SA-model for similar y+ values
lucfd is on a distinguished road
I am running a case which is derived from the OpenFOAM/tutorials/periodicHill (steady state). That is, the set-up used which serves as initial conditions for the time-domain simulation using LES.
The main changes are 1) 2D 2) free stream rather than channel flow. Flow conditions are kept the same.
In order to achieve this, I have modified:
p
|  \\    /   O peration     | Version:  v2312                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    "(inlet|outlet)"
        type            cyclic;
    "(front|back)"
        type            empty;
    "(hills)"
        type            zeroGradient;
    "(top)"
        type            freestreamPressure;
        freestreamValue $internalField;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (1e-3 0 0);
boundaryField
    "(inlet|outlet)"
        type            cyclic;
    "(front|back)"
        type            empty;
    "(hills)"
        type            noSlip;
    "(top)"
        type            freestreamVelocity;
nut
FoamFile
    version     2.0;
    format      ascii;
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    "(inlet|outlet)"
        type            cyclic;
    "(front|back)"
        type            empty;
    "(hills)"
        type            nutUSpaldingWallFunction;
        value           $internalField;
    "(top)"
        type            freestream;
        freestreamValue           uniform 0;
nuTilda
FoamFile
    version     2.0;
    format      ascii;
    object      nuTilda;
internalField   uniform 1e-8;
boundaryField
    "(inlet|outlet)"
        type            cyclic;
    "(front|back)"
        type            empty;
    "(hills)"
        type            fixedValue;
        value           uniform 0;
    "(top)"
        type            freestream;
fvOptions
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvOptions;
//momentumSource
//    type            meanVelocityForce;
//    selectionMode   cellZone;
//    cellZone        inletCellZone;
//    fields          (U);
//    Ubar            (1 0 0);
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver          GAMG;
        smoother        DICGaussSeidel;
        tolerance       1e-06;
        relTol          0.05;
    "(U|k|nuTilda)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-05;
        relTol          0.1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    consistent      yes;
    //pRefCell        0;
    //pRefValue       0;
relaxationFactors
    equations
        U           0.9;
        nuTilda     0.7;
The main modifications are changing "top" to 'patch', and imposing freestream boundary conditions rather than wall conditions. Moreover, I had to turn off momentumSource because this is not longer applicable to external flow problems. I also turned off pRefCell and pRefValue in fvSolution because according to me this is being taken care of by the freestream BC.
So far, I did not modify the blockMeshDict. But, using the original settings this means a very fine resolution for the now freestream BC. The solver returns that I have a very (very) fine mesh near the wall.
yPlus yPlus write:
    writing field yPlus
    patch hills y+ : min = 4.3852231e-05, max = 0.001221246, average = 0.00049500734
Nevertheless, I have a convergent result as shown in the image (pressure) I attached. Of course, I might have to increase the height of the freestream patch. But, I want to focus on the effect of modifying blockMeshDict. There, I changed
simpleGrading (1 ((0.5 0.5 100)(0.5 0.5 0.01)) 1)
to
simpleGrading (1 400 1)
in order to maintain a very fine grid. The results however, do not converge as shown in the second image. The solver returns
patch hills y+ : min = 2.0608024e-05, max = 0.00050223013, average = 0.00019107119
My questions is why? What could possibly cause the stable solution to become unstable only by removing refinement near the freestream patch but remaining very fine near the wall.
lucfd is offline   Reply With Quote
grid convergence, y plus selection
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
DrivAer car model Convergence MarkT FLUENT 0 April 21, 2015 11:23
Jump in epsilon values near the wall : low re k-epsilon model malaboss OpenFOAM Verification & Validation 1 February 1, 2013 17:36
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Convergence problems with SSG turbulence model Ram CFX 1 June 19, 2006 11:08
