Which solver for incompressible heat transfer simulation ? |
November 1, 2024, 10:17 |
Pierre LECHEVALIER
Rep Power: 3 |
I would like to perform a very simple simulation with water circulating in a straight tube (200mm long and 15mm diameter) with heating walls. Knowing that I am using water circulating at "low" velocity (<20 m/s), I would like to use an incompressible solver. "incompressibleFluid" is great but do not seems to be able to consider heat transfer in native form (or I am wrong ?). That's why I use "fluid" which is dedicated to heat transfer situation but this is a compressible solver... Hence my question, does anyone know if there is an incompressible solver to solve also the energy equation in OpenFoam? Thank you for your help, Best regards, Pierre |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid | Rockda | FLUENT | 24 | August 30, 2016 07:33 |
New guy trying to solve his first simple Heat Transfer simulation. | BhaluBear | OpenFOAM | 2 | August 12, 2014 13:54 |
Question about heat transfer simulation | Anna Tian | Main CFD Forum | 0 | January 25, 2013 19:53 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
