Adding a source term to the pressure Poisson equation results in pressure divergence
Old   October 31, 2024, 08:34
Post Adding a source term to the pressure Poisson equation results in pressure divergence
shamiaoluo
BUAA LSM is on a distinguished road
When solving cavitation, the multiphase flow model uses the vof model, and the source term is added to the phase fraction equation and the pressure Poisson equation, as shown in the figure. However, it is strange that when the source term is not added to the pressure Poisson equation, the pressure field is convergent, but the phase fraction field is wrong. After the source term is added, when cavitation occurs, the source term is not 0 and the pressure field diverges. I'm pretty sure the openfoam code has source term in it.
I used the code written by myself, the pressure and speed coupling used the SIMPLE algorithm, the interface capture used the CICSAM method, the processing of source terms used explicit expression and implicit expression, and the results were divergent.
I tried a lot of methods and I couldn't solve the divergence problem, the cavitation model was the Schnerr and Sauer model
BUAA LSM is offline   Reply With Quote
cavitation, pressure poisson equation, source term
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
