how to use dynamicCode lib for new simulations
Old   October 21, 2024, 05:03
Default how to use dynamicCode lib for new simulations
Yi Dai
zrxdaly is on a distinguished road
Hi openfoamers,
I recently started to learn OpenFOAM, and I want to use OpenFOAM to simulate heat and moisture transfer between multi-region. I am using openfoamv12. The heat transfer part is easy, I copy paste the tutorial code from $FOAM_TUTORIALS/multiRegion/CHT/coolingCylinder2D. I tried to add a water content variable in this case. I tried to adapt Dr. Tobias Holzmann moisture module in OFv12 without success.
Then I found out in the testing case ($WM_PROJECT_DIR/test/multiphaseEuler/thermal/waterEvaporation/), there is already cases about water evaporation. The code is simulated in zero dimension and it generates a dynamicCode library after running ./Allrun. I am still reading the source code to understand how this case works and how to use it in 2D or 3D.
I appreciate any comments and helps.
Dai
zrxdaly is offline   Reply With Quote
cht, heat tranfer, moisture
3D simulations OpenFoam running too low(more 1 000 000 elements) Suggestion speed up? silvai OpenFOAM Running, Solving & CFD 4 April 6, 2017 12:44
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM hjasak OpenFOAM Announcements from Other Sources 2 February 13, 2017 05:59
Atmospheric Nitrogen Plasma DBD simulations aminem COMSOL 0 November 25, 2016 09:56
Please Help...CFD Simulations Workstation sharath chandra Hardware 1 May 15, 2016 03:18
URANS and Transient Simulations bob Main CFD Forum 0 October 1, 2003 04:54
