Singularity cylinder mesh in OpenFOAM
Old   October 16, 2024, 15:33
Default Singularity cylinder mesh in OpenFOAM
Hyeonwoo Nam
Hywoo is on a distinguished road
Hi Foamers,
I have found that OpenFOAM can handle meshes with a singularity at the center of a cylinder(Attachment). It appears that this type of mesh contains a singularity at the pole. Could anyone explain how OpenFOAM handles such meshes?
Thanks,
Hywoo
Hywoo is offline   Reply With Quote
Old   October 18, 2024, 14:01
Tobermory will become famous soon enough
By "singularity", I assume you are referring to the fact that all a large number of cells share a common vertex on the centreline of the cylinder? (it's not a common use of the term singularity, but I guess I can see what you mean).
As for OpenFOAM - it simply doesn't care. The FV cells communicate with each other through their shared faces ... and don't care about their vertices. Hope that helps.
Tobermory is offline   Reply With Quote
[mesh manipulation] Multi-region mesh from .stl files in OpenFoam V7 carl_r OpenFOAM Meshing & Mesh Conversion 11 December 11, 2024 09:06
Prescribed Translating Cylinder Mesh for Added Mass Problem (Transient FSI) Lloyd Sullivan CFX 5 August 7, 2018 09:11
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
