Two Phase Flow - Water Jet Reflection at Outlet |
October 16, 2024, 06:24 |
Umut
Rep Power: 15 |
Hi everyone,
I’m currently working on a two-phase flow simulation using OpenFOAM's interFoam solver (a test case to learn two phase flow modelling). The case I'm modeling is a 2D laminar flow where water flows from a hole in a bottle. I used the damBreak tutorial as a base and set a fine, uniform mesh with 1 mm edge lengths. (Mesh image below) The issue I'm facing is that the water jet gets partially reflected from the outlet, while I want the outlet to behave as atmosphere. The expected outcome was for the water jet to leave the domain smoothly, as if there was nothing at the outlet. Please see the video: https://drive.google.com/file/d/1OKJ...ew?usp=sharing I suspect the boundary conditions may not be properly set to allow for a smooth exit of the flow. Top surface on the left zone (bottle) is inletAir. Top, right, bottom surfaces of right zone (atmoshpere) is outletWater, all other boundaries are walls except frontAndBack. Here are the boundary conditions I've used: U: Code:
boundaryField { walls { type noSlip; } outletWater { type pressureInletOutletVelocity; value uniform (0 0 0); } inletAir { type pressureInletOutletVelocity; value uniform (0 0 0); } frontAndBack { type empty; } } Code:
boundaryField { walls { type zeroGradient; } outletWater { type inletOutlet; inletValue uniform 0; value uniform 0; } inletAir { type inletOutlet; inletValue uniform 0; value uniform 0; } frontAndBack { type empty; } } Code:
boundaryField { walls { type fixedFluxPressure; value uniform 0; } outletWater { type totalPressure; p0 uniform 0; } inletAir { type totalPressure; p0 uniform 0; } frontAndBack { type empty; } } https://drive.google.com/file/d/1dH0...ew?usp=sharing |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 13:16 |
Discrete Phase Model, outlet mass flow rate does not fit | edu_aero | FLUENT | 29 | February 3, 2020 09:38 |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 15:27 |
setting OUTLET flow rate equal to INLET flow rate | spitchers | OpenFOAM Programming & Development | 0 | March 22, 2018 07:33 |
2 Phase Flow, Gas Jet into Water Simulation Method | im_lenny | OpenFOAM | 3 | May 4, 2017 04:20 |
