Solution when running OpenFOAM in directories with spaces
Old   October 12, 2024, 20:59
Default Solution when running OpenFOAM in directories with spaces
TWB
quarkz is on a distinguished road
Hi, I'm using dropbox enterprise in my sch with Win11 and the root folder is something like "ABC dropbox". Then inside is another folder with my name "XYZ TYU".
I tried to run OF thru WSL in windows and it gives error after the decomposePar.
Anyone has a solution? I tried to use symbolic link but it can't work. I tried to change the registry so that dropbox will use a folder with no spaces but also failed.
OF in windows with:
Native Windows : Cross-compiled Windows binaries (mingw).
Provides a quick means of using OpenFOAM on windows, but does not
currently include an OpenFOAM development environment
(ie, cannot compile code, no dynamic code)
This one works but as mentioned, cannot compile code, no dynamic code just is what I need sometimes.
Thanks for reading.
quarkz is offline   Reply With Quote
'Signal: Segmentation fault (11)' while running openFoam in Parallel Processing jaymeen721 OpenFOAM Running, Solving & CFD 1 April 10, 2023 20:17
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
Random machine freezes when running several OpenFoam jobs simultaneously 2bias OpenFOAM Installation 5 July 2, 2010 08:40
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
