Negativeinitial temperatureT0 when simulating a heating rod(chtMultiRegionFoam))
Old   October 11, 2024, 00:33
Post Negativeinitial temperatureT0 when simulating a heating rod(chtMultiRegionFoam))
Yungeng Li
Amos Li is on a distinguished road
I am fairly new to OpenFoam using version v2312,
I encountered the following error while simulating a heat transfer problem (chtMultiRegionFoam) in a fuel rod in the nuclear reactor:
--> FOAM FATAL ERROR: (openfoam-2312)
Negative initial temperature T0: -1.04187e+11
From Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::rhoConst<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::rho Const<Foam::specie> >, Foam::sensibleEnthalpy>]
in file /home/liyungeng/OpenFOAM/OpenFOAM-v2312/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 57.
FOAM aborting
Here's the model I used:
The blue area is the fuel rod(heat source),green area is the coolant,red and yellow areas are the clad.Does anybody know a solution, please?
Amos Li is offline   Reply With Quote
Old   October 11, 2024, 10:05
Sami Safarini
samisafarini is on a distinguished road
Can you post the case files?
Have you initialised your fields correctly?
samisafarini is offline   Reply With Quote
Old   October 14, 2024, 04:23
Yungeng Li
Hello!
Here is my case files:
https://drive.google.com/file/d/1KRw...usp=drive_link
I don't see what's wrong with the boundary conditions. Could you please help me take a look when you have a moment? Thank you!
chtmulitregionfoam, nuclear fuel
Simple way of simulating heating from sun Hawxliquid OpenFOAM Running, Solving & CFD 9 August 22, 2023 05:43
Harmonic Balance FE Magnetic Vector Potential Model is not simulating eddy currents smisbahu STAR-CCM+ 0 February 10, 2023 17:51
Comparison of under-floor heating and radiator heating Mountainbike OpenFOAM Running, Solving & CFD 1 November 27, 2020 07:55
Heating value of fuel in non-premixed model? Jeronimo97 FLUENT 0 February 15, 2013 15:27
Simulating roof heating in sun Arakis CFX 3 December 29, 2009 19:24
