Problem with sixDoFRigidBodyMotionRestraint and floating body |
October 10, 2024, 10:22 |
Tom SALIC
Rep Power: 3 |
Hi foamers,
I'm looking to simulate a floating object subjected to waves and held by 11 mooring lines. Before relying on the Foam mooring module, I want to use the restraint function "linearAxialAngularSpring" available with the librairy : dynamlicMotionSolverFvMEsh. The test case works very well with th 'sixDoFRigidBodyMotionConstraint axis" constraint function, but when I configure the number of mooring lines the simulation diverges. Have you encountered this problem before? I used stiffness and damping parameters for the lines based on values from TLP (Tension Leg Platform). In this configuration, the lines are tensioned to keep the floating body in position. But when looking at the position of the center of gravity, it takes values on the order of 10e+24, enough to change galaxies . How is that possible? I am attaching the folder, but i cannot attach the STL file as it exceeds the maximum size. Thank you for your responses and any help Last edited by salicTo; October 11, 2024 at 10:24. |
floating body, interfoam, mooring, restraints |
How to numerically simulate the dynamic net wall and floating body | ShowHan | REEF3D | 6 | July 22, 2024 23:37 |
A floating body of irregular, uneven density | Sun qi | REEF3D | 1 | April 13, 2022 05:15 |
6dof model - floating body | flinde | FLUENT | 13 | March 6, 2021 15:32 |
Floating body: explosions in the sky | Phicau | OpenFOAM Running, Solving & CFD | 1 | February 4, 2014 05:37 |
6DOF with floating body bounce back. | paka | FLUENT | 4 | June 6, 2013 12:32 |
