Badly formed bounding box - Strange!!!
Old   October 9, 2024, 22:45
Default Badly formed bounding box - Strange!!!
Desh
dasith0001 is on a distinguished road
Hi Foamers,
I am experiencing bit of a strange occurrence of
PHP Code:
error!.
I am running a CHT case on OpenFOAM version 12. The domain is a 22.5 deg of wedge section and BCs with symmetry conditions. The mesh is generated on Ansys and converted to foam mesh via fluentMeshToFoam or fluent3DMeshToFoam. ( The error is common to both mesh conversions).
My mesh is also relatively good.
PHP Code:
Checking geometry...
Overall domain bounding box (0.000872496007073 0.000117537397458 0.1) (0.368900105047 0.181510575685 1.4462)
Mesh has 3 geometric (non-empty/wedgedirections (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Max cell openness 6.41616449837e-15 OK.
Max aspect ratio 437.945792086 OK.
Minimum face area 8.21350118675e-09Maximum face area 0.000360849193815.  Face area magnitudes OK.
Min volume 5.98435821164e-12Max volume 3.44527899463e-06.  Total volume 0.0364164568208.  Cell volumes OK.
Mesh non-orthogonality Max88.970975067 average24.3193080843
*Number of severely non-orthogonal (> 70 degreesfaces6718.
    Non
-orthogonality check OK.
Face pyramids OK.
Max skewness 3.92324883293 OK.
Coupled point location match (average 0OK
Also, following this link,
HTML Code:
https://www.cfd-online.com/Forums/openfoam-bugs/74441-directmappedpatch-badly-formed-bounding-box.html
My geometry do not sit on plane or an axis.
NOW THE STRANGE PART,
1. The error goes away if I add inflation layers.
2.The error is back if I remove the inflation layers.
3.The error is repeatable with varied size of the elements in the mesh.
Your suggestions to resolve the issue is highly appreciated, let me know if you need more information on this.
Thank you
Dasith
dasith0001 is offline   Reply With Quote
cht, v12
[surface handling] Command line tool for finding the bounding box of an STL file terrybarnaby OpenFOAM Meshing & Mesh Conversion 8 November 4, 2016 14:09
SnappyHexMesh plane surface bounding box podallaire OpenFOAM Bugs 22 August 26, 2009 08:34
bounding box in tgrid 3.6.8 Anthony ANSYS Meshing & Geometry 4 July 30, 2009 13:23
bounding box in tgrid 3.6 Anthony ANSYS 0 July 28, 2009 09:43
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 22:20
