For Validation
Old   October 9, 2024, 13:28
Post For Validation
Dilip
dthakur is on a distinguished road
I need to validate one case and i am having problem to set up a given equation . like in which openfoam file i can find nonlinear damping and cubic term. i am using simpletic solver for my case related to flow induced heaving and pitching any idea or help would be really appreciated.
dthakur is offline   Reply With Quote
Old   October 10, 2024, 07:12
Default Bit more background needed
Skill-Lync CFD
CFD_with_Skill-Lync is on a distinguished road
Can you explain the physics a little bit? It would help in narrowing down the terms you would need to focus on.
Also, please mention the OpenFOAM version you are using.
Regards
Team Skill-Lync
CFD_with_Skill-Lync is offline   Reply With Quote
Old   October 10, 2024, 10:22
Dilip
I'm working on validating a NACA 0012 airfoil and need to simulate flow-induced heaving and pitching. The equations in my reference paper include both linear and non-linear terms. My question is where to implement the non-linear terms in OpenFOAM. I understand that the 6DOF solid body framework has solvers and folders for constraints and restraints. In my case, I have a linear and angular spring with no damper, but the equations include non-linear terms in the stiffness (K) component. Where should I incorporate these non-linear and coupling terms?
Old   October 14, 2024, 04:28
Skill-Lync CFD
The 6DOF solver can take a text file input with time vs location. If you are interested, you could give the motion of your airfoil as a tabulated input to your dynamicMeshDict file.
Instead, OpenFOAM foundation uses #calc function where you can directly input your motion with respect to time, while defining the X, Y and Z coordinates of your object.
If you want to incorporate the equations for motion of your object, these are two ways in which you could do it. I would advise start with the tabulated 6DOF, it's relatively easier as all it would take you is a simple Python script to write the text file.
Old   October 14, 2024, 11:16
Dilip
can you share more details how to put #calc in dynamicMeshDictFile. my equations has non linear terms as well and i have to find pitching and heaving motion. equations are attached
Old   October 25, 2024, 14:54
Dilip
In my study of vortex-induced vibrations (VIV) for a vibrating cylinder, I have a mass ratio m* is 10 Re = 100 and Ur* from 4 to 8. I am trying to determine which parameters to adjust in order to achieve different amplitudes of vibration for the cylinder at these various reduced velocities. However, I am encountering an issue where I observe the same amplitude at each reduced velocity, regardless of the changes I make. Can someone explain why this might be happening? I appreciate any insights, as I am conducting this analysis using OpenFOAM.
