One inlet for gas and liquid, two outlets
Old   October 4, 2024, 11:39
Question One inlet for gas and liquid, two outlets
Elvin
Elvin is on a distinguished road
Hello, dear OF users. I am investigating a pipe of diameter X, which has a common inlet divided for gas and liquid. This pipe also has an outlet of diameter X. In addition, there is a tube of 6 times smaller diameter (Y), flowing out of this pipe. I am wondering what boundary conditions need to be set to make the liquid in the smaller diameter tube the same as in the larger tube. Is this possible at all? I have tried opening all the outlets and setting the pressure either in the cell to zero or at the main outlet. I am using the interFoam solver with the k-omega turbulence model.
Thanks in advance!
Elvin is offline   Reply With Quote
boundary conditions, interfoam, pipe
Inlet definition in VOF TALEMWA EMMANUEL Fluent Multiphase 1 September 7, 2019 12:32
Free turbulent water jet into liquid metal pool, inlet submerged Estone Fluent Multiphase 1 February 22, 2019 14:39
Reversed flow using pressure inlet and outlet? here_for_help FLUENT 0 September 28, 2018 16:20
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
