[rhoSimpleFoam] - Manifold geometry - Solving Issues |
October 4, 2024, 09:27 |
Rep Power: 2 |
Hello everybody,
I need your support to solve a challenging situation I face with rhoSimpleFoam solver. I'd like to compare results between StarCCM+ and OpenFOAM for a simple air manifold case. Both runs with SIMPLE solver using compressible and similar settings. It perfectly runs with STARCCM+ but it quickly stops (after 6 iterations) with OpenFOAM 2312. The key facts are: ->The OpenFoam case works only if I set the solver SIMPLEC. This leads to different results between StarCCM+ and OpenFOAM. As soon as the consistent option is deactivated the solver crashes. ->Mesh has been checked ->If I reduce by 70% the inlet massflowrate it works but if I set a ramp the computation crashes when reaching 50% of the targeted massflowrate. -> I've also tried to play with under relaxation coefficient without any success Before I eventually share some setting information. Do you have any ideas of what could be the reasons of such issue? Thank you in advance for your help |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 10:48 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
