Dynamic mesh floating body case with symmetry plane
Old   September 27, 2024, 08:31
Default Dynamic mesh floating body case with symmetry plane
Samuel N.
samuelnobrecg is on a distinguished road
Good morning,
I am trying to simulate a pitch decay test of a 3d-hull with symmetry to reduce the ammount of cells. I am using rigidBodyMotion solver for the dynamic mesh and limitind the only degree of freedon to rotation in Y direction. I run the case until 0.01s and then apply an angular velocity of 0.05rad/s with a timestep of 0.01s leading to a Courant number of ~0.3. However, the mesh update seems to crash when reaching 0.37° of displacement at 0.26s and it also happened for different refinement levels and different timeSteps/Courant numbers.
This crash is different from the common crash due to bad setup of inner and outer distance in dynamicMeshDict since it happens at a low displacement and squishes the mesh in a strict region, losing the hull local geometry and also deforming the mesh in the direction normal to the symmetry plane.
My masters project is still ongoing so I can't share the mesh or full geometry of the hull but I can share the case setup and a screenshot of the region before and after the sudden deformation. The mesh was generated in Ansys Mesher with ~1.3kk cells where the closest layer of cells have 0.1m of thickness.
I am not familiar to adjusting the numerical parameters in fvSchemes and fvSolution, so I am using the default values of the floatingObject tutorial. The same setup worked fine for a 2d case (without symmetry) for roll decay simulation. So I guess that it has something to do with the interaction between the mesh recalculation and the symmetry plane.
I would like to know if anyone has faced a similar problem or has a clue of which parameter should I focus on adjusting to ensure the stability of the mesh recalculation to avoid this type of mesh crash.
Thank you for the attention!
Samuel
samuelnobrecg is offline   Reply With Quote
dynamic mesh;, floating body, symmetry bc
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Floating point exception in dynamic mesh simulation Helium Fluent UDF and Scheme Programming 0 September 20, 2019 04:43
dynamic mesh case based of an interFoam case maxonline OpenFOAM Running, Solving & CFD 3 February 21, 2016 15:13
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
