Bounding k and omega problems
Old   September 26, 2024, 04:39
Post Bounding k and omega problems
Kazan
火山口玩泥巴 is on a distinguished road
I'm a new foamer running a case in OpenFOAM (v2312) where I have trouble with solution convergence and bounding of k and omega.
The case is a transient 3d channel flow with one inflow and one outflow.
The solver I used in this case is interFoam because of the mutiphase.
I used blockMesh to build the mesh and simplified the mesh to make sure there are no problems for mesh qulities.(It has been checked by checkMesh)
For turbulence I'm using the k-omega SST model which is not so sensetive to the initial conditions (I'm not sure)
For boundary conditions (sry I can't the code function):
U:
inlet
type fixedValue;
value uniform (10 0 0);
walls
type noSlip;
atmosphere
type pressureInletOutletVelocity;
value uniform (0 0 0);
outlet
type outletPhaseMeanVelocity;
Umean 15;
alpha alpha.water;
value $internalField;
p_rgh:
atmosphere
type totalPressure;
p0 uniform 0;
inlet
type zeroGradient;
outlet
type zeroGradient;
walls
type fixedFluxPressure;
value uniform 0;
k:
inlet
type fixedValue;
walls
type kqRWallFunction;
outlet
type inletOutlet;
inletValue uniform 0;
atmosphere
type inletOutlet;
inletValue $internalField;
omega:
inlet
type fixedValue;
walls
type omegaWallFunction;
outlet
type inletOutlet;
atmosphere
type inletOutlet;
alpha.water:
inlet
type fixedValue;
value uniform 1;
walls
type zeroGradient;
outlet
type variableHeightFlowRate;
lowerBound 0;
upperBound 1;
value uniform 0;
atmosphere
type inletOutlet;
value uniform 0;
For initial conditions, I have set the k = 5, omega = 40, p_rhg = 0, when I set the U = 10 while setting a specific area of region alpha.water = 1 by setFields, it can run. However when I try to set the U = 0 or less area of region to be water, then the program will get divergency with reporting bonding omega and bonding k.
What is the reason for the problem mentioned above?
And how can I solve it? By resetting initial conditions of k and omega or something else?
火山口玩泥巴 is offline   Reply With Quote
Old   September 26, 2024, 05:12
Kazan
Because I don't have the permission to post the picture, I can't show my mesh directly. So I put the code of blockMeshDict here:
scale 1;
vertices //
(0 0 0) //0
(28 0 0) //1
(0 2 0) //2
(28 2 0) //3
(48 2 0) //4
(0 3 0) //5
(28 3 0) //6
(48 3 0) //7
(0 7 0) //8
(28 7 0) //9
(48 7 0) //10
(0 16 0) //11
(28 16 0) //12
(48 16 0) //13
(0 0 6) //14
(28 0 6) //15
(0 2 6) //16
(28 2 6) //17
(48 2 6) //18
(0 3 6) //19
(28 3 6) //20
(48 3 6) //21
(0 7 6) //22
(28 7 6) //23
(48 7 6) //24
(0 16 6) //25
(28 16 6) //26
(48 16 6) //27
blocks
hex (0 1 3 2 14 15 17 16) (35 5 5) simpleGrading (1 1 1)
hex (2 3 6 5 16 17 20 19) (35 3 5) simpleGrading (1 1 1)
hex (3 4 7 6 17 18 21 20) (25 3 5) simpleGrading (1 1 1)
hex (5 6 9 8 19 20 23 22) (35 15 5) simpleGrading (1 1 1)
hex (6 7 10 9 20 21 24 23) (25 15 5) simpleGrading (1 1 1)
hex (8 9 12 11 22 23 26 25) (35 15 5) simpleGrading (1 1 1)
hex (9 10 13 12 23 24 27 26) (25 15 5) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(8 5 19 22)
(5 2 16 19)
(2 0 14 16)
walls
type wall;
faces
(11 8 22 25)
(0 1 15 14)
(1 3 17 15)
(3 4 18 17)
(1 0 2 3)
(3 2 5 6)
(4 3 6 7)
(6 5 8 9)
(7 6 9 10)
(9 8 11 12)
(10 9 12 13)
(14 15 17 16)
(16 17 20 19)
(17 18 21 20)
(19 20 23 22)
(20 21 24 23)
(22 23 26 25)
(23 24 27 26)
outlet
type patch;
faces
(4 7 21 18)
(7 10 24 21)
(10 13 27 24)
atmosphere
type patch;
faces
(12 11 25 26)
(13 12 26 27)
komegasst, komegasst interfoam
Bounding Omega problems // Number of lambda iterations exceeds maxLambdaIter(10) Marie_Dal OpenFOAM 6 July 17, 2023 04:58
Compressible nozzle flow - no problem for fluent but impossible with openFOAM? flar.t OpenFOAM Running, Solving & CFD 10 March 30, 2022 02:21
Bounding k and omega problems BendikS OpenFOAM Running, Solving & CFD 7 December 20, 2021 05:38
[solids4Foam] How to calculate drag coeff when using solids4Foam amuzeshi OpenFOAM CC Toolkits for Fluid-Structure Interaction 15 November 7, 2019 13:50
Internal Flow Instability with layers Zephiro88 OpenFOAM Running, Solving & CFD 1 June 20, 2019 05:20
