FireFoam/reactingFoam combustion with Arrhenius reaction rate parameters too slow
Old   September 24, 2024, 09:14
Default FireFoam/reactingFoam combustion with Arrhenius reaction rate parameters too slow
sphere is on a distinguished road
Hello everyone,
I am trying to simulate laminar diffusion flame combustion in fireFoam using not infinitely fast chemistry, as mostly used in the tutorials, but calculating the reaction rates using arrhenius reaction rates. For that, i use the "laminar" combustion model and define Arrhenius parameters A and Ta in constant/reactions. The reaction is a single step, second order reaction. Somehow, the parameters obtained from literature lead to way lower/slower combustion than expected. Both temperature and the conversion are too low.
Does anyone know, why that could be or could give me hints on how I should approach that problem?
The solution does not seem to be greatly mesh dependent. I am using openFoam v2212. Am I right in assuming the units to be m^3/kmol/s for A and K for Ta?
sphere is offline   Reply With Quote
firefoam, reactingfoam
The reaction rate for a wall surface reaction stanlee8 FLUENT 0 July 22, 2023 12:12
Error in New Surface reaction model (Having multiple reactions) surajkvs OpenFOAM Programming & Development 2 May 23, 2023 22:21
Arrhenius equation for combustion - numerical stiffness issue manukamin Main CFD Forum 0 June 19, 2021 02:43
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
