subsetMesh and solidDisplacementFoam :calculate the hole mesh error
Old   September 22, 2024, 05:30
Default subsetMesh and solidDisplacementFoam :calculate the hole mesh error
Yinghao Zhou
Yinghao Zhou is on a distinguished road
Hello everyone!
I am using solidDisplacementFoam to solve thermal stress. I built a cube model and used the subsetMesh command to dig out some of the mesh to form a porous structure. But I got an error when I ran it.
I tried to merge the oldInternalFaces formed by the grid into other patches or define it as a separate patch, but it still reported an error. But I can run it without subsetMesh.
could anyone help me?
The following is the error message
Create time
Create mesh for time = 0
Reading mechanical properties
Normalising E : E/rho
Calculating Lame's coefficients
Plane Strain
Reading thermal properties
Normalising k : k/rho
Calculating thermal coefficients
Reading field D
Reading field T
Calculating stress field sigmaD
Calculating explicit part of div(sigma) divSigmaExp
Calculating displacement field
Iteration: 1
DICPCG:  Solving for T, Initial residual = 0.625951, Final residual = 0.0112757, No Iterations 17
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib64/libc.so.6"
#3  Foam::DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) at ??:?
#4  Foam::DICPreconditioner::DICPreconditioner(Foam::lduMatrix::solver const&, Foam::dictionary const&) at ??:?
#5  Foam::lduMatrix::preconditioner::addsymMatrixConstructorToTable<Foam::DICPreconditioner>::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) at ??:?
#6  Foam::lduMatrix::preconditioner::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) at ??:?
#7  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#8  ? at ??:?
#9  ? at ??:?
#10  ? at ??:?
#11  ? at ??:?
#12  __libc_start_main in "/lib64/libc.so.6"
#13  ? at ??:?
[IMG]
Yinghao Zhou is offline   Reply With Quote
Calculate field and patch averages in multiple zones, large mesh buffi OpenFOAM Post-Processing 2 July 21, 2022 06:45
[mesh manipulation] manipulation of an unstructerd mesh HandsomePotato OpenFOAM Meshing & Mesh Conversion 0 February 17, 2020 15:19
printstack error caused by subsetMesh error jiahui_93 OpenFOAM Running, Solving & CFD 0 March 29, 2018 02:29
[foam-extend.org] 3.2 Installation in Debian 8.5 jsm OpenFOAM Installation 2 June 19, 2016 11:53
[mesh manipulation] CreatePatch after subsetMesh maka OpenFOAM Meshing & Mesh Conversion 2 August 27, 2008 08:28
