Floating point exception
Old   September 10, 2024, 06:31
Default Floating point exception
Jehan Sharook Rassdeen
Jehan99 is on a distinguished road
I am new to OPENFOAM. I am starting to model ammonia combustion. So i selected SandiaD_LTS tutorial and converted ammonia instead of methane and upload different chemical mechanism to it and then run. I did basic changes (Boundary conditions likewise) and run parallel. after running with the reactingFoam i got this error.
Chemistry time solved max/min : 0.04953202103 / 4.837881048e-06
[stack trace]
#1 Foam::sigFpe::sigHandler(int) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#2 ? in /lib/x86_64-linux-gnu/libc.so.6
#3 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libspecie.so
#4 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libchemistryModel.so
#5 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libchemistryModel.so
#6 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libchemistryModel.so
#7 Foam::seulex::seul(double, Foam::Field<double> const&, double, int, Foam::Field<double>&, Foam::Field<double> const&) const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libODE.so
#8 Foam::seulex::solve(double&, Foam::Field<double>&, Foam::ODESolver::stepState&) const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libODE.so
#9 Foam::ODESolver::solve(double, double, Foam::Field<double>&, double&) const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libODE.so
#10 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libchemistryModel.so
#11 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libchemistryModel.so
#12 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libcombustionModels.so
#13 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/reactingFoam
#14 ? in /lib/x86_64-linux-gnu/libc.so.6
#15 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#16 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/reactingFoam
what is the reason for that? Please help
Jehan99 is offline   Reply With Quote
Old   November 15, 2024, 05:38
Default same
aymen
ayme_nn is on a distinguished road
Hi.
i'm having kind of the same issue, did you manage to solve the problem ?
ayme_nn is offline   Reply With Quote
ammonia combustion, combustion model, floating point error, floating point exception, openfoam
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 12:43
A floating point exception has occurred: floating point exception [Overflow]. starlight STAR-CCM+ 4 May 4, 2016 10:08
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 05:57
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 14:56
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 20:28
