Total flow volume mismatch for inflow and outflow
Old   September 9, 2024, 18:06
Default Total flow volume mismatch for inflow and outflow
Abdullah Saifee
saifee is on a distinguished road
I am running an incompressible laminar flow simulation with the pimpleFoam solver. It has two openings on one side (n1 and n2) and one on the other (n3). I have set up the pressure boundary conditions so that the flow is driven primarily by the pressure applied at n3. The flow should be changing direction halfway. Realistically, the total volume passing through an opening should be the same for the two flow direction. Yet, when I sum over the patch flow rates (postProcessing function) of the two flow directions and compare them, they are different. What could be the potential reason(s) for this phenomenon?
Following is the pressure boundary condition I set up:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  10
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    n1
		type            totalPressure;
		p0              uniform 0;  // Reference total pressure (e.g., atmospheric pressure in Pascals)
		U               U;               // Velocity field name
		phi             phi;             // Flux field name
		rho             none;            // Density, use 'none' for incompressible flow
		psi             none;            // Compressibility, use 'none' for incompressible flow
		gamma           1;               // For incompressible flow, use 1
	n2
		type            totalPressure;
		U               U;
		phi             phi;
		rho             none;
		psi             none;
		gamma           1;
    n3
		type		uniformTotalPressure;
	p0
		type		sine;
		frequency	0.3333333333333333;
		amplitude	-50.0;
		level		0;
    walls
        type            zeroGradient;
    defaultFaces
        type            empty;
and U boundary condition:
|  \\    /   O peration     | Version:  v2006                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    n1
	type 		pressureInletOutletVelocity;
	value		uniform (0 0 0);
    n2
    n3
    walls
        type            noSlip;
    defaultFaces
        type            empty;
saifee is offline   Reply With Quote
flowrate, incompressible, laminar, openfoam, openfoam 10.0
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
outflow boundary condition ravi_adepu FLUENT 11 January 19, 2018 08:13
Total pressure and mass flow boundary condition at inlet bscphil OpenFOAM Pre-Processing 3 July 9, 2017 15:39
potentialFoam doesnt start?! Sway OpenFOAM Running, Solving & CFD 0 July 2, 2015 08:48
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 12:14
