September 7, 2024, 12:22 |
chtMultiRegionSimpleFoam min/max rho 0
Francisco Gómez
Hi everyone.
I'm starting to use Openfoam and I have some doubts with an error I got. I'm simulating a simple heat transfer problem involving a simple heat sink and air. I started the problem using the cpuCabinet tutorial files, and I did the geometry and mesh using Salome. The error I got shows a min rho value of 0. I am using the perfect gas equation of state for air, so I tried using rhoConst equation of state to solve the 0 rho value. When I tried this, I got other error that the temperature was negative. I already tried to limit the temperature, but I don't if it didn't work or I didn't place this limit in the correct folder (fvOptions, but which directory?). This is the error for min rho = 0 value: Code:
Time = 1 Solving for fluid region fluid DILUPBiCGStab: Solving for Ux, Initial residual = 1, Final residual = 0.042796894, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 1, Final residual = 0.038868498, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 1, Final residual = 0.028137352, No Iterations 1 Solving energy coupled regions Creating lduPrimitiveAssembly: lduAssembly3 DILUPBiCGStab: Solving for h, Initial residual = 0.99893615, Final residual = 0.027460353, No Iterations 2 FDICPBiCGStab: Solving for p_rgh, Initial residual = 0.56125707, Final residual = 0.0053949441, No Iterations 29 time step continuity errors : sum local = 0.41127749, global = -0.013829449, cumulative = -0.013829449 Min/max rho:0 3.8594714 [stack trace] ============= #1 Foam::sigFpe::sigHandler(int) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #2 ? in /lib/x86_64-linux-gnu/libc.so.6 #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #4 Foam::compressibleTurbulenceModel::phi() const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libcompressibleTurbulenceModels.so #5 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libcompressibleTurbulenceModels.so #6 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionSimpleFoam #7 ? in /lib/x86_64-linux-gnu/libc.so.6 #8 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #9 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionSimpleFoam ============= Floating point exception I hope somebody can give me a hand on this problem. https://drive.google.com/drive/folde...usp=drive_link |
#heattransfer #error |
rho and rhoFinal in fvSolution and others | NewKid | OpenFOAM Running, Solving & CFD | 3 | July 15, 2019 09:36 |
rSF: p divergence in combustor (wt negative value) | zonda | OpenFOAM Pre-Processing | 4 | April 10, 2018 06:59 |
chtMultiRegionFoam- too slow | sandymech1 | OpenFOAM Running, Solving & CFD | 4 | November 20, 2017 18:51 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
