Mesh deformation with overset (ESI/overInterDyMFoam)) |
September 5, 2024, 08:26 |
Rep Power: 6 |
Hi everyone,
I'm trying to run some overset water entry/slamming cases with overInterDyMFoam and using a simple wedge drop case for validation and testing, using the case files here: as a base. The background grid is Cartesian and there is a moving foreground mesh with a wedge. The initial mesh setup is shown in the first attached image. however, after some time, the surface of the wedge starts to deform and it develops a "crinkled" surface. The stage of the simulation where this occurs changes depending on the initial conditions but it appears to happen as the body passes through a horizontal plane in the domain. The surface ends up as shown in the second image. Obviously this impacts the accuracy of the simulation and destroys any useful results, as the suface of the wedge is not smooth. Any ideas on what might cause this? The pointDisplacement patch for the wedge surface is defined as Code:
floatingObject { type calculated; value uniform (0 0 0); } Best regards, Vivio Last edited by Vivio; September 5, 2024 at 08:48. Reason: images not displaying. attached as files instead. |
dynamic mesh, mesh quality, overset, rigid body motion |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 15:16 |
Overset mesh not acting as an overset mesh | JoostLinthorst | OpenFOAM Running, Solving & CFD | 0 | March 12, 2021 09:53 |
help with setting up overset mesh | calv | FLUENT | 0 | May 14, 2017 09:12 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
