driftfluxfoam diverges
Old   September 2, 2024, 09:14
Default driftfluxfoam diverges
Andy
Starcatcher is on a distinguished road
Hi folks,
this is my case:
driftfluxfoam, 3D-mesh with very good quality, alpha.sludge inlet 0.0024
buoyantKEpsilon turbulence model
I tried this setup with a slamm mesh (sudo-2d), no problem
When i try it on a bigger mesh ca. 4mio cells, the simulation diverges in the epsilon-transport equation. setting turbulence to laminar solves the issue.
What could be the reason? I really would like to use turbulence here.
Thank you
Starcatcher is offline   Reply With Quote
The run diverges sometimes fatihyaman661 Fidelity CFD 2 September 12, 2024 05:08
The alphaeqn in 2 phase incomprossible flow (driftFluxFoam) Elol OpenFOAM Running, Solving & CFD 2 March 16, 2022 13:40
Problem diverges when exhaust valve opens swerner0711 AVL FIRE 0 September 21, 2018 08:14
If my problem diverges in OpenFOAM ver3, will it work in 5 quarkz OpenFOAM Running, Solving & CFD 3 April 26, 2018 03:09
New Viscosity model in DriftFluxFoam yang.l OpenFOAM 2 December 2, 2017 07:56
