September 1, 2024, 02:40 |
Phase not getting patched or selected
BIRENDRA MANDAL
I am trying to simulate a split T junction in openFoam using the InterFoam capillaryRise case file using PISO. I have generated the mesh using Fluent. But while patching the phases in setFieldsDict, no cells are getting selected for the water phase. Where am I going wrong??
Alpha.water file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class volScalarField; location "0"; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet_oil { type fixedValue; value uniform 0; } inlet_water { type fixedValue; value uniform 1; } outlet_1 { type zeroGradient; } outlet_2 { type zeroGradient; } walls { type constantAlphaContactAngle; theta0 145; limit gradient; value uniform 0; } } // ************************************************** *********************** // p_rgh file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet_oil { type fixedFluxPressure; } inlet_water { type fixedFluxPressure; } outlet_1 { type fixedValue; value uniform 0; } U_file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet_oil { type fixedValue; value uniform (0.0278 0 0); // flow in x-dir } inlet_water { type fixedValue; value uniform (0 0.00833 0); // flow in y-dir } outlet_1 { type zeroGradient; } outlet_2 { type zeroGradient; } walls { type fixedValue; value uniform (0 0 0); } defaultFaces { type fixedValue; value uniform ( 0 0 0 ); } } // ************************************************** *********************** // g_file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class uniformDimensionedVectorField; object g; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -2 0 0 0 0]; value (0 0 -9.81); // gravity in neg z-dir // ************************************************** *********************** // transportProperties_file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object transportProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // phases (water oil); water { transportModel Newtonian; nu [ 0 2 -1 0 0 0 0 ] 9.808e-07; rho [ 1 -3 0 0 0 0 0 ] 938; } oil { transportModel Newtonian; nu [ 0 2 -1 0 0 0 0 ] 0.00003337869; rho [ 1 -3 0 0 0 0 0 ] 859.83; } sigma 0.00436; // surface tension in N/m // ************************************************** *********************** // turbulenceProperties_file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object turbulenceProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType laminar; // ************************************************** *********************** // ControlDict_file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application interFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 1; deltaT 1e-5; writeControl adjustable; writeInterval 0.005; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.25; maxAlphaCo 0.2; maxDeltaT 1; // ************************************************** *********************** // fvSchemes_file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(U) Gauss linear; grad(p) Gauss linear; grad(alpha) Gauss linear; // Green-Gauss node-based gradient calculation } divSchemes { default none; div(rhoPhi,U) Gauss linearUpwind grad(U); // Second-order upwind for velocity div(phi,alpha) Gauss vanLeer; // For VOF method, sometimes PLIC is handled internally div(phirb,alpha) Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } // ************************************************** *********************** // fvSolution_file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { alpha.water { nAlphaCorr 1; nAlphaSubCycles 2; cAlpha 1; solver smoothSolver; tolerance 1e-07; relTol 0; } "pcorr.*" { solver PCG; preconditioner DIC; tolerance 1e-10; relTol 0; } p_rgh { solver PCG; preconditioner DIC; tolerance 1e-07; relTol 0.05; } p_rghFinal { $p_rgh; tolerance 1e-07; relTol 0; } U { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-06; relTol 0.05; } UFinal { $U; tolerance 1e-06; relTol 0; } } PISO { nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; momentumPredictor yes; } // ************************************************** *********************** // setFieldsDict_file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha.water 0 ); regions ( boxToCell { box (-1.83697e-20 -0.0003 0) (0.00155 0.00065 0.0001); fieldValues ( volScalarFieldValue alpha.water 0 ); } boxToCell { box (0.000249999 -0.00029999 0.0001) (0.000349999 -0.00014999999 0); fieldValues ( volScalarFieldValue alpha.water 1 ); } ); // ************************************************** *********************** // I am unable to understand where I am going wrong or missing something. Please help. |
#openfoam #debug |
Sharing links for two phase solver packages developed by openfoam community | swap_9068 | OpenFOAM Programming & Development | 1 | April 2, 2017 05:43 |
Adding an energy source term to a phase with reactions | lxlxlxt | Fluent Multiphase | 0 | February 10, 2014 20:42 |
multi phase flow with chemical reactions in one phase | Habibfateh | OpenFOAM Programming & Development | 0 | February 10, 2014 07:33 |
Derive fixed number of phase from clone () in multiphaseEulerFoam Solver | Aj Nair | OpenFOAM Programming & Development | 0 | December 16, 2013 20:41 |
two Phase column simulation | chemeng | OpenFOAM | 3 | August 18, 2010 12:53 |
