'Final residual = nan' on the first timestep
Old   August 28, 2024, 10:44
Default 'Final residual = nan' on the first timestep
n936an is on a distinguished road
Running a compressible flow over a 737 wing here. As soon as it reaches the first timestep (t=0.1), the final residual for "solving for e" comes out as "nan" and over the next few timesteps all other values also inevitably end up as nan.
I don't have much experience in setting up new cases so I'd appreciate it if you could look at my files and see if I made any mistakes.
Below is my case directory.
https://drive.google.com/file/d/1yR3...ew?usp=sharing
And here is what I see when running the simulation:
Create time
Create mesh for time = 0
Selecting solver fluid
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
RAS
    model           kOmegaSST;
    turbulence      on;
    printCoeffs     on;
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
No MRF models present
Selecting patchDistMethod meshWave
Selecting thermophysical transport type RAS
Selecting default RAS thermophysical transport model unityLewisEddyDiffusivity
PIMPLE: Convergence criteria found
        p: tolerance 0.0001
        U: tolerance 0.0001
        "(k|omega|epsilon)": tolerance 0.0001
PIMPLE: Operating solver in steady-state mode with 1 outer corrector
PIMPLE: Operating solver in SIMPLE mode
Starting time loop
forcesBase forces:
    Not including porosity effects
forces forces:
forceCoeffs forces:
forceCoeffs forces write:
    Cm    = 0.000956058
    Cd    = 0.000574535
    Cl    = 4.41614e-06
    Cl(f) = 0.000958266
    Cl(r) = -0.00095385
Time = 0.1s
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0667967, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0593224, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0677076, No Iterations 2
smoothSolver:  Solving for e, Initial residual = 1, Final residual = nan, No Iterations 1000
smoothSolver:  Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000
time step continuity errors : sum local = nan, global = nan, cumulative = nan
smoothSolver:  Solving for omega, Initial residual = nan, Final residual = nan, No Iterations 1000
smoothSolver:  Solving for k, Initial residual = nan, Final residual = nan, No Iterations 1000
ExecutionTime = 66.7093 s  ClockTime = 67 s
    Cm    = -nan
    Cd    = -nan
    Cl    = -nan
    Cl(f) = -nan
    Cl(r) = -nan
I believe a similar topic was posted several years ago but that thread did not receive a full answer it seems.
Many thanks.
n936an is offline   Reply With Quote
rhoSimpleFoam High Pressure Cell Crashes Simulation NorthCFD OpenFOAM Running, Solving & CFD 0 March 3, 2023 06:02
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
