AdjointOptimisationFOAM - Use latest optimized mesh and run RANS+LES |
August 27, 2024, 02:58 |
André Pinto
Rep Power: 8 |
In my current workflow I use RANS+LES to run unsteady simulations.
Recently I started using AdjointOptimisationFOAM to help me with ideas for optimizing the shape (vehicle). My current procedure for adjoint is running between 5 to 10 iterations on a local part of the vehicle and hopefully be able to observe a clear trend of mesh movement that it's advised. I then morph this in the initial geometry, export and run RANS+LES with the normal workflow. Problem is that this ends up being time consuming and a lot of times, since adjointOptimisationFoam is running RANS, the LES result is underwhelm. Would anyone have any pointers or ideas, on how would I go about running a 10 iterations loop adjointOptimisationFOAM, and at the end, pickup the morphed mesh, and directly launch it in my normal workflow RANS+LES? I replicated this manually by downloading constant, then merging the "points" generated in the 10th iteration folder and launching the case like that, but since I'm using a cluster, would be very usefull to be able to do this automatically and at once! |
parallel run in foam extend | CRI_CFD | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 5 | March 28, 2024 08:36 |
Sajben Transonic Diffuser Benchmark: RANS is great, struggling with LES | CSMDakota | SU2 | 5 | October 11, 2023 04:08 |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
